New to me with issues NLT
At least I don't think so. I just picked up a 2002 Z06 and really like it. But.........
1) It's too loud. Can I trade someond for a stock exhaust or does the Borla Cat Back eliminate too many stock parts? Or does someone have an idea how to quiet this down?
2) Is an aftermarket partition for the rear worth the money? I think I could make one out of particle board and carpet it.
3) My manual says the car should have skip shift (it doesn't). Is this a big deal?
4) The manual also says the trans. will go into first < 40 mph. Mine won't go into first at a stop without grinding. Is this something someone added or is the first gear syncro going? The seller told me it won't go into first at anything > 6 mph as if it was a factory feature.
5) This has an aftermarket shifter (I don't know which brand), and it is really hard to shift. Is this normal? My '90 roadster shifted great by comparison.
Thanks in advance
Jim
1st Congrads on the Vette and welcome to the forum.The only things I could comment on are the partition I was going to make one, for $160 to my door not to bad a deal and I'm happy with it.
Also, about the exhaust I'm sure someone will have a great deal for ya and some stock unit, without looking under the car to see what all has been changed out, would be hard to comment on. Could have headers and x-pipe and lastly the Borla's.....All those components are bolt on, unless someone did some serious modding, But again without seeing it you wouldn't know for sure. good luck and have fun
If the tranny will not shift into first without grinding you have a problem. Could be the clutch is not releasing all the way or the first gear synchros are going. Not too good either way.
If the after market shifter is a short throw shifter you will find it takes a bit more effort to change gears. I have one in my Z06 and once I got used to it I really like it. Now the shifter in our BMW M roadster seems floppy and imprecise by comparison.
Good luck with the first gear problem.
2) I have both a solid and foam partition. The foam sealed well, but let more sound through. The solid ones are better if they fit properly.
3) Skip shift = pain in the ***. I suspect your car has a tune. Any other mods you are aware of?
4) Agreed. You have a trans issue that needs to be fixed. My 2002 Z06 downshifts to first at 40 mph.
5) I've also been through three shifters: Stock, B&M, and now RSD Snap Shifter. Stock one felt vague and not very positive with long throws. The B&M was positive but notchy and high effort. The RSD Snap Shifter is very smooth and easy to use. Just about perfect.
There is a skip shift kit in it because the light comes on saying first to fourth but it doesn't so I'm happy there.
I'm getting used to the shifter and kinda like it.
I'm sure there is an issue with first gear. Clutch works fine. Any recommendations? I have lots of wrenches and know how to use them. Does doing a tranny involve dropping the whole drive train?
Thanks, guys, for the help.
jim
Yes it does, not to bad a job though. Go here: http://www.cajundude.com/c5techhome.htm and click on Dope's clutch how to writeup to see what you're up against. Sounds like it might be a wearing synchro, how fast are you going when you downshift?
Also, post up a pic of the exhaust and we'll be able to tell you what it is. Taking a pic of the headers would be a good idea too if it's really that loud.
The stock Titanium exhause is a great system, and lighter weight than any aftermarket option. I would highly recommend it.
There is a CAD drawing of a template for it floating around the forum somewhere. others also have life size templates they could mail you upon request.
Check your shifter alignment. This is a very common problem for people having a hard time getting into 1st.
Thanks in advance
Jim
I can get into first only when stopped and it is best to do it from another gear, not neutral and then first. I can sit all day in first with the clutch in and no discernible drag, so I'm ruling out the clutch. I will look into adjusting the shift mechanism, but I think there is something wrong with the trans.
I'm learning how to drive a low noise profile by shifting at lower speeds and less power. I still haven't ruled out stock exhaust trades though. Now I'm going to search for partitions and shifter adjustments.
Man does this thing have HP.
jim
I've been reading about trans repairs and am just wondering if taking out the trans. would be possible without dropping the drive line. It has to be removed anyway, so.....
I'm going to drain the oil in all the boxes and see what I get in the way of chips or whatever. I looked at the way shift kits are installed and it doesn't look like a shifter adjustment would help my issue. I will also examine clutch issues.
jim
