underdrive pulley???
Old Jun 10, 2011 | 09:46 AM
kjmj's Avatar
kjmj
Default underdrive pulley???
Any need to retune after installing an underdrive pulley? Car has a tune for the heads and cam that were installed in feb 2011. Thanks for your help.
Old Jun 10, 2011 | 09:53 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
NO - it's not a bolt that it will effect the tune! It's more like an unleashing of hidden power being robbed by turning mass -
Lighten turning mass and you increase the power!
Thanks,Matt
Old Jun 10, 2011 | 10:04 AM
kjmj's Avatar
kjmj
Thanks. That was my thought too. Just wanted to confirm from people that have more knowledge about this than me. Thanks for your help.
Old Jun 10, 2011 | 01:40 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Maybe a stupid question, anyone put on a underdrive pulley in a stock vetted with no issues? Is it worth it?
Old Jun 10, 2011 | 01:55 PM
dougbfresh's Avatar
dougbfresh
Many have put it on-waste of time and money.
Old Jun 10, 2011 | 02:02 PM
japc5's Avatar
japc5
Yes there are plenty of people who have done it and not to increase performance rather to replace a defective OEM under drive pulley. I am one such person who went with a Powerbond over re-installing another GM pulley that is known to separate and wobble.
Old Jun 10, 2011 | 03:23 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Not really worth it if the OE pulley is fine. It's a fair amount of work to swap it out. Most go to an underdrive pulley when installing a cam since it's got to be removed anyway to swap the cam out.
Old Jun 10, 2011 | 04:00 PM
mcm95403's Avatar
mcm95403
Don't know what scuttlebutt you've read, but I could immediately tell how much more the car wanted to rev when I had mine installed. My stocker was coming apart, so it was well worth the time and money.
Old Jun 10, 2011 | 05:27 PM
Quick Draw's Avatar
Quick Draw
Not trying to hijack thread, but how do you know what size serpentine belt to get for the smaller pulley?
Old Jun 10, 2011 | 06:11 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
All you have to do is ask here on this forum..or ask the undrive pulley vendor, they should have the correct swapout belt chart when using their HB. As far as putting an under drive pulley on your C5... ! As theses cars become older, the OEM Crank pulley is looking for a reason to delaminate or wobble due to a backed out bolt.. In either case the potential is there.. with an underdrive pulley You remove any threat of a delamination, and you pick up about 10 ponies.. the job is fairly straight forward.. Shop time is 4 hours.. pulleys are around 200 dollars. the big thing is proper torque procedure. If you can do the job yourself ,,, the 200 dollars for the pulley and new bolt is worth it. Shop time @ 90 an hour is 360 dollars.. two new belts are about 40 dollars. Also , with a new pulley you will want to use either a Gaytorback or a Gates...the reason is the design of the ribs in relation to the overall width.. many cheap belts do not afford the clearance that gates and Gaytorback do...this clearance is what helps to make the pulley system quiet.. there are only a few thousandths clearance in some cases.. the AC Belt which runs behind the balancer first stage ( drive belt ribs ) can easily come in contact with the belt if the belt is designed poorly.. the run out ( grooves to width ) is a critical dimension on a C5. AS the cars get older , the pulley bearings allow the pulleys to wobble slightly, thus creating a wider run out.. so you need additional clearance which is afforded by either Goodyear Gatorback or Gates.. Many people have talked about Goodyear Gatorbacks as curing their problem but no one has actually offered the reason why.. So Now you got it... Gates is just as good as Gaytorback, and you can get them at NAPA.. its their belt brand but they are made by Gates...
Bill aka ET
Old Jun 10, 2011 | 06:25 PM
dougbfresh's Avatar
dougbfresh
What do you think underdrive pulleys actually do?
Old Jun 11, 2011 | 07:00 AM
Quick Draw's Avatar
Quick Draw
Originally Posted by Evil-Twin
All you have to do is ask here on this forum..or ask the undrive pulley vendor, they should have the correct swapout belt chart when using their HB. As far as putting an under drive pulley on your C5... ! As theses cars become older, the OEM Crank pulley is looking for a reason to delaminate or wobble due to a backed out bolt.. In either case the potential is there.. with an underdrive pulley You remove any threat of a delamination, and you pick up about 10 ponies.. the job is fairly straight forward.. Shop time is 4 hours.. pulleys are around 200 dollars. the big thing is proper torque procedure. If you can do the job yourself ,,, the 200 dollars for the pulley and new bolt is worth it. Shop time @ 90 an hour is 360 dollars.. two new belts are about 40 dollars. Also , with a new pulley you will want to use either a Gaytorback or a Gates...the reason is the design of the ribs in relation to the overall width.. many cheap belts do not afford the clearance that gates and Gaytorback do...this clearance is what helps to make the pulley system quiet.. there is only a few thousandths clearance in some cases.. the AC Belt which runs behind the balancer first styage ( drive belt ribs ) can easily come in contact with the belt if the belt is designed cheaply.. the run out ( grooves to width ) is a critical dimension on a C5. AS the cars get older , the pulley bearings allow the pulleys to wobble slightly, this created a wider run out.. so you need additional clearance which is afforded by eitherGoodyear Gatorback or Gates.. Many people have talked about Goodyear Gato backs as curing their problem but no one has actually offered the reason why.. So Now you got it...
Bill aka ET
Thanks E.T.
This exactly the information I was looking for. New pulley and 10 extra h.p. is great.
Thanks again for helping us guys who do not have the knowledge we need.... and realize it.
Old Jun 17, 2011 | 10:40 PM
kjmj's Avatar
kjmj
Well, new tuner said we needed to adjust the tune. He said after the new underdrive it was knocking. Said he could fix everything up for me. I guess my old tuner/builder that put on used parts, which is the reason I had to do the underdrive pulley really is not that good. Looking forward to getting the car back. It has been a couple of months since I got to go for a spin.
Old Jun 17, 2011 | 11:19 PM
mcm95403's Avatar
mcm95403
Mine washes and waxes the car, keeps it vacuumed and automatically moves it out of the way of falling bird poop when it's parked in a parking lot. When it's not doing all that it's slowing down the speed of the accessories and reducing the load and parasitic drag on the engine.
Old Aug 26, 2011 | 02:47 PM
Scoundrl's Avatar
Scoundrl
No tuner around here is going to do that job for 4 hours. I did it on mine and if you do it right and pin the pulley you are looking at 8 at least. I would not have done it if I wasn't swapping cams, the price/performance is just not there. As for tune, no need for a tune with a simple underdrive swap, if you are knocking after you have some other tuning issues but its pretty unlikely its because of the pully itself.
-Ken
Old Aug 26, 2011 | 03:06 PM
02*C5's Avatar
02*C5
The money/hp makes the ud pully not worth it. I also did mine, had issues with over heating, and when I took it off I saw a 2 hp difference. Money and time wasted.
Old Aug 26, 2011 | 03:22 PM
chassed's Avatar
chassed
Hahahaha NICE!
Old Aug 26, 2011 | 07:53 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Dang, parasites in your engine, gonna get Orkin to look at mine.
To underdrive pulley???
