I need some advice and help info PLEASE! :)
I want a Corvette and I am going to find one today. lol..
I have $3,000 cash to put down on a C5. What kind of things do I need to look for when shopping for a Corvette?
Bad signs ect..
I found several 98-01's for around $14k-16k at one car lot.
I am headed over there today around 4pm.
Any help, info ect... would be great before I buy one! Thanks!
~Chandra
One of the big things is to look to see if it's been wrecked before. Carfax may tell you some of that, but a lot doesn't get reported on carfax. You can check around the trunk area and around the engine bay for some evidence of repairs (seams, funky paint, etc.). Other indications are if the rear or front bumper colors are slightly different from the fenders, most body shops have a hard time getting the paint to match between the plastic bits and the fiberglass bits of the car as well as they did from the factory.
Also, get it checked out by a mechanic that YOU choose, particularly if you don't have a lot of detailed service history that you can look through on the car.
nothing earlier than a 2000 if your shopping used C5's, some options begame standard on the later models, ie: HUD Display - a must have option, once you see it, you'll have to have it.. So later models the better....
Good luck and make sure to post pics when the deal's done
Only thing is its up in Dallas and I don't know any mechanics there but I do in my town. I will look them over good and test drive a few as well. I'm really excited! lol..
I have only drove a 84 Corvette and driven in a 94 and a 99 I believe. The other one I rode in was with a professional race car driver and it was like a 06 I think? We went around a race track and through some sharp curves, and WOW you could not slap the smile off my face! lol...
Note that there is a button above the checklist to print it out so that you can take a copy with you when you look at the car.
I would also recommend that you ask about taking the car to someone you trust that has the ability to put the car up in the air so that you can look at the bottom to check for any scrapes or damage. If you were anywhere near the Tempe Arizona area, I'd do it for you! Good luck and don't settle...get the one you want!
good luck and let us know if we can help.
That ^ is what the ad says... of the car I looked at today... I started it up and it sounded mean... I did not see a scratch on it. I am going for this one. Wish me luck guys and gals... ;-)
Make sure you get on the gas a few times (tho u don't sound like a girl that needs any encouragement for that
) Hit the brakes hard enough to engage abs. Take a couple of turns with the wheel hard over (low speed) to check the cv joints. The synchros and shift forks on the stock t56 are junk, listen for grinding and be sure to notice if effort is increased shifting into any one gear in particular (definitely pay close attention going into second and fourth). On a straight road let go of the steering wheel and see if the car pulls in any direction.When you get back to the lot pull the codes again and check out the ones that have reappeared. You can post them on here and we'll tell you if there are any you need to be particularly concerned about. Also pull the kick panel on the passenger side floorboard (under the floor mat all the way to the front) and look for any indication that the area has gotten wet recently (damp to the touch, moldy smell, etc). then it's just the basic stuff: headlights, fog lights, windows, seat controls, ac modes, radio, fuel door release, horn etc. Not a bad idea to check the harmonic balancer at idle for excessive wobbling (largest pulley on the drive belt system located lower center).
Other than that, if it feels good go for it! You only live once
Here's a link to another post that explains in detail how to use the DIC to pull trouble codes courtesy of Bill Curlee... http://forums.corvetteforum.com/1577842685-post2.html
OH OH
