Sea Foam
Old Jun 10, 2011 | 03:29 PM
sabastian458's Avatar
sabastian458
Default Sea Foam
I just installed an engine in my Z06, and when I put oil in it I also put 10oz of SeaFoam in the crankcase. I am about to take the car to be tuned this week, should I removed the SeaFoam? (perform an oil change) Or will the 10oz be ok to run?
Old Jun 10, 2011 | 04:07 PM
robert miller's Avatar
robert miller
As long as the car is not smoking like crazy you will be fine on it. One of them that you add will let the car smoke like crazy man Hope it not the one in the crankcase. But if not smoking will be good to go
Old Jun 10, 2011 | 04:12 PM
sabastian458
It smokes when it is reved, but I contribute that the the fueling being way off, mostly black smoke out the tail.
Old Jun 10, 2011 | 04:23 PM
VinnyT's Avatar
VinnyT
Is it a daily driver or will it sit until you take it for a tune?
Old Jun 10, 2011 | 04:25 PM
sabastian458
It has been sitting, I am taking it Saturday to drop off for a week, then it will go back to the garage. It is an 02 with 19k miles
Old Jun 10, 2011 | 04:28 PM
VinnyT's Avatar
VinnyT
You'll be fine. I accidentally poured a half a quart of tranny fluid in the oil once(Mobil 1 oil & tanny fluid quarts are both silver ). Drove it for a week before changing the oil. No harm.
Old Jun 10, 2011 | 04:34 PM
baxsom's Avatar
baxsom
seafoam will thin out the oil. It is made up of light petroleum, rubbing alcohol, and naptha. i wouldnt want anything in my oil that does that during a dyno run.
Old Jun 10, 2011 | 04:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I think I'm going to agree here. I don't think it will hurt to drive around a few days (kinda like an oil flush) but I wouldn't take my car anywhere near redline with anything but good quality oil in the crankcase.
JMHO
Old Jun 10, 2011 | 05:08 PM
sabastian458
Ya'll think a drain and fill will be fine, or should I go ahead and do the filter too? New Filter installed with the engine.
Old Jun 10, 2011 | 05:13 PM
SaberD's Avatar
SaberD
ive heard of people intentionally putting trans fluid in the oil and running around 50 miles to help clean the engine before an oil change. it acts as a detergent, and cleans out a lot of gunk. not sure how good it is for your car though, so i stay away from this process. i doubt it hurts it though.
Old Jun 12, 2011 | 11:26 AM
jbondfl's Avatar
jbondfl
Change the filter. Its low cost and holds about 15% of your oil. No sense only changing part of the oil if you are going to the effort at all.
Old Jun 12, 2011 | 12:51 PM
rebelheart's Avatar
rebelheart
To Sea Foam
