A/C noise
Old Jun 11, 2011 | 08:15 AM
thaitime's Avatar
thaitime
Default A/C noise
I have a noise that seems to be getting louder over time only when my A/C is turned on as soon as you shut the A/C off it off it stops, which leads me to believe it is something to do with the A/C clutch any help would be appreciated I have sprayed the belts all down with belt dressing to help locate the problem to the A/C compressor area.
thanks in advance
Old Jun 11, 2011 | 08:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
What type of noise? Grinding, crunching, squeaking?
Does it blow cold when you use it or is it mostly warm air?
Any more info will be appreciated.
Thanks,Matt
Old Jun 11, 2011 | 10:53 AM
thaitime's Avatar
thaitime
The A/C does blow cold and the sound is like two metal plates rubbing together with a squeaking sound.
Old Jun 11, 2011 | 12:43 PM
thaitime's Avatar
thaitime
Here is a sound clip of the noise from turning on/off the A/C
http://www.youtube.com/watch?v=-DK7-j6rqz0
Old Jun 11, 2011 | 12:49 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I had a rattling sound out of my '99 which is a bad compressor, yet surprisingly it worked just fine with lots of cold air. I finally replaced it and no more noise.
Old Jun 11, 2011 | 01:49 PM
thaitime's Avatar
thaitime
Did yours have the same sound as the clip I posted of mine? May I ask what you paid for a compressor?
thanks in advance
Old Jun 11, 2011 | 04:34 PM
dgrant3830's Avatar
dgrant3830
I had the dealer do it for me to insure it was all done with a new compressor and not a rebuilt. As I remember, the bill came to $1400 but that was several years ago.
Old Jun 11, 2011 | 04:49 PM
thaitime's Avatar
thaitime
Thank you, I am hoping my problem is less expensive but with my luck???
Old Jun 11, 2011 | 08:34 PM
MIKER's Avatar
MIKER
Sounds like the A/C compressor clutch to me. Mine is starting make a similar noise. At least clutch failure doesn't contaminate the system internals like a failed compressor.
Shop around to see if anyone sells a replacement clutch. Often time these days you cannot buy the consumable parts for certain components. The only option is to purchase the whole part.
Old Jun 11, 2011 | 10:16 PM
Devo2133's Avatar
Devo2133
3rd Gear
Default AC Compressor
It's the AC compressor. I know because this just happened to me last week. Overtime it will begin getting pretty noisy (uncontrollably) over 2k rpm. You will know if you let it go without letting a mechanic look at it...and you eventually smell freon, which is after the compressor has gone out. Mine went from somewhat noticeable to broken in about a week. Hopefully it might just be a vacuum seal or something. That would be only 350ish versus 1600 for the compressor.
Good Luck
Old Jun 11, 2011 | 10:33 PM
sliderhd's Avatar
sliderhd
I am finishing up changing mine now. Got vacuum pulled just waiting on morning to finish. Not too bad a job just a lot to do. I had the same noise exactly. Compressor about $450 from Gene at gmpartshouse. Be sure to use a new compressor. I have had zero luck with rebuilds over the years. The quote above should include changing the accumulator and orifice tube. Must do's when changing a compressor. Good luck.
Old Jun 11, 2011 | 11:27 PM
madmatt9471
Okay, it sounds like the clutch, like others have said, if you ever have to put gauges on it and you turn the AC on and the pressures stay the same or equal between the two then that means it has bypassed inside and the inwards have failed -
In either case at this point your clutch will continue to fail and that is much better than the insides failing and leaving debris - at this point it is pretty straight forward and you can replace the AC compressor without having to replace the condensor and other supporting mods -
Thanks,Matt
Old Jun 12, 2011 | 07:01 PM
thaitime's Avatar
thaitime
Wow guy's thanks so much for all the advice, I had a feeling it was the compressor/clutch $450.00 is not the end of the world for a compressor but it looks like it's time to see what the local A/C shop gives for a compressor install quote.
To A/C noise
