Are C5 and C6 corvettes unibodies? What exactly is a unibody?Anyone ever wrecked a corvette(c5/c6) and fixed it or fixed a wrecked one? Any problems that you run into with the frame? Any help is greatly appriciated!
Corvettes have always been FULL FRAME cars-want to know what a UNIBODY is? Try GOOGLE!
As already stated, Corvette's have always been produced on a frame. A unibody is basically a car constructed without a frame as you would think of a frame. It uses the body and panels as the frame of old.
As far as repairing a Corvette that has been in a wreck, that is a hard question to answer. If the frame has not been bent then it can be as simply removing the damaged parts and replacing them or repairing the existing part with fiberglass matt and resin. I repaired the rear quarter panel on my '66 many years ago.
How ever if you are not well schooled in body repait, I would suggest leaving it to a professional.
A unibody really means the body and it's underpinnings act as the frame and hold the car together and provide its strength and rigidity. This saves weight since the frame normally weighs so much. But with a fiberglass or plastic body, it would be very hard to do and have enought strength.
Ok so the corvette is a full frame car but what does Hydroformed mean?
a great explanation of the process (and the innovation at the time) can be found in the book "all corvettes are red". it should be required corvette reading, particularly if you have or are considering a C5, or just a corvette "history" buff. great insight into GM and the development (or lack thereof at times) of the C5 into a production vehicle.
Sigh.........Yes unfortunatly I have Dukes of Hazzard one of mine into a car. Still have nightmares about my baby flying in the air and coming down on a 2010 Caddy......Long Story.......But she was totaled so i didnt get to fix her. Rant over, man i feel so much better now... Jay
Shame...did you get another one to replace it though?
Originally Posted by taknute
Interesting....I'll try to look into it more..do they sell that book at bookstores or only online?
A large bookstore may have a copy, but it is a pretty old book. You might have to get them to order one or try a place like Amazon.com or maybe even the NCM.
Starting with the C5 the metal frame is 'Hydro-formed' or in plain words, it goes into a tube and pressurized at 10.000 psi. The method of forming the frame is such that it doesn't deform or destruct the metal molecules and gives you a better frame in rigidity and consistent shape & then galvanized. But the book goes into much better an description.
I think the theory is with equal pressure from the inside a while forming, the thickness around the frame will be equal. Imagine an expanding ballon, the thickness on the surface of the ballon is equal as it expands.
And with less welding involved, there's probably a significant savings in weight in addition to structural rigidity. To bad the C5/Z06 frame wasn't aluminum like the C6/Z06.
