Can anyone read Code?
Old Jun 20, 2011 | 09:49 PM
C5-1's Avatar
C5-1
Default Can anyone read Code?
I was looking at the cars computer code history and this is what came out.
CODE LIST
10-PCM (Powertrain Control Module) P1431 Fuel Level Sensor 2 Circuit Performance H
28 TCS (Traction Control System) C1221 LF Wheel Speed Sensor Input Signal is 0 H
C1222 RF Wheel Speed Sensor Input Signal is 0 H
C1254---Did not find in C5 Computer Codes
80-RADIO U1000---Did not find in C5 Computer Codes H
A0-LDCM (Left Door Control Module) B2282 Battery #1 Fault H
B2284 Battery #2 Fault H
U1064 Loss of Communications with BCM H
A1-RDCM (Right Door Control Module) B2282---Did not find in C5 Computer Codes H
B2285 Battery #2 Fault H
A6-SCM (Seat Control Module) B0851 Battery 1 Out of Range H
B0-RFA (Remote Function Actuation) U1255---Did not find in C5 Computer Codes H
U1096 Loss of Communication with IPC H
Is there anything on this list that I should fix? I know the H stands for history, but that does mean it is no longer an issue?
Old Jun 20, 2011 | 11:18 PM
Boo383's Avatar
Boo383
Yes H is history. You should be able to go through there and reset all these codes. If they pop back up then you might want to be concerned with them.
Old Jun 20, 2011 | 11:45 PM
jrose7004's Avatar
jrose7004
http://api.viglink.com/api/click?for...%2F2000dtc.php
To Can anyone read Code?
