Low and High Psi levels?
Old Jun 20, 2011 | 09:54 PM
C5-1's Avatar
C5-1
Default Low and High Psi levels?
My 98 C5 is always alerting me that my tires psi are either high or low. Sometimes it is alerting me of the fronts and sometimes for the rears...I am riding with the correct tire pressure (the one recomended on the tire sidewall).
What am I doing wrong?
Old Jun 20, 2011 | 10:10 PM
spdislife's Avatar
spdislife
If you're using an accurate gauge, and the pressures are where they should be, then you're not doing anything wrong.
I have a daily driver that signals me after about 50 miles of highway driving that I've got low tire pressures. Once I confirmed the car is wrong, I've ignored the warning for the last 6 years.
Old Jun 20, 2011 | 10:17 PM
C5-1's Avatar
C5-1
So everytime you are going over 50mph you get the signal? or is it occasionally?
Old Jun 20, 2011 | 10:20 PM
LoneStarFRC's Avatar
LoneStarFRC
You just answered your own question.
Old Jun 20, 2011 | 10:23 PM
spdislife's Avatar
spdislife
No...after driving about 50 miles the warning comes on. I've just learned to ignore it.
Old Jun 20, 2011 | 10:28 PM
Try setting your tires at 30 psi cold - that is what is recommended on the sticker inside the drivers door area. Do not go by the psi listed on the tire sidewall.
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
You don't want to use the pressure on the sidewall of the tire, A good starting point is 30psi cold on all four tires and after they warm up driving you will have about 34 psi in the tires and you should not get the message any more.
The recomended tire pressure for the car is on the drivers door.
Mr.Bill
Old Jun 20, 2011 | 11:51 PM
C5-1's Avatar
C5-1
ill try checking the psi when they are cold...Thanks!
Old Jun 21, 2011 | 06:35 AM
steve8's Avatar
steve8
That explains the high, but not the low.
To Low and High Psi levels?
