* Injector SPECIAL *
Old Jun 23, 2011 | 04:18 PM
Jennifer @ TPE's Avatar
Jennifer @ TPE
St. Jude Donor '12
Default * Injector SPECIAL *
INJECTOR SPECIAL:
MORE THAN 10% OFF PLUS FREE SHIPPING
Siemens DEKA IV Mototron 80lb/hr High Impedance Injectors with EV1 or USCAR Connector
$389 shipped
anywhere in the lower 48 states
These retail for $439.99
These injectors flow 80 lbs/hr at 43.5 PSI ( 3 BAR ) and even more at greater PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are able to function at high fuel pressures and don’t exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
Specifications:
  • Static Flow Rate: 80lb/hr = 875 cc/min
  • Dynamic Flow Rate : 18.6 mg/pulse 2.5ms PW, 20 ms Period
  • Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
  • Connector: Bosch EV1
  • Series: DEKA 4 ( DEKA IV )
  • O-Ring Type: Viton
Siemens DEKA IV Mototron 60lb/hr High Impedance Injectors (Long or Short Style) with EV1 or USCAR Connector
$359 shipped
These retail for $399.99
These injectors flow 60 lbs/hr at 43.5 PSI ( 3 BAR ) and up to 85 lbs/hr at 87 PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
Specifications:
  • Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
  • Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
  • Gain: 0.11ms/mg
  • Offset: 0.055ms
  • Turn on time @ 14VDC: 1.14ms
  • Turn off time: 0.85ms @ 600KPa
  • Orifice Type: Multi-orifice
  • Spray Pattern: 30 Degree Spray Cone
  • Factory fitted with Viton upper and lower o-rings
ALL INJECTORS FLOW MATCHED WITHIN 1% FROM THE FACTORY
You can purchase these via paypal to Jeff@TotalPerformanceEngineering.com, or by calling me at the shop (702) 632-0270.
Old Jun 23, 2011 | 04:43 PM
kris6868's Avatar
kris6868
Any 42 lbs injectors on sale?
Old Jun 23, 2011 | 05:24 PM
Jennifer @ TPE
St. Jude Donor '12
We don't currently have any, but we can get some. They would be $330 shipped.
Old Jun 27, 2011 | 02:12 PM
Jennifer @ TPE
St. Jude Donor '12
I am currently packaging up all orders that came in over the weekend. You will have tracking numbers here shortly
Old Jun 29, 2011 | 02:47 PM
Jennifer @ TPE
St. Jude Donor '12
ttt
Old Jul 5, 2011 | 05:07 PM
Jennifer @ TPE
St. Jude Donor '12
Bump
Old Jul 11, 2011 | 03:54 PM
Jennifer @ TPE
St. Jude Donor '12
This sale is good through the end of this week ONLY!!! Don't miss out!
Old Jul 12, 2011 | 06:10 PM
Jennifer @ TPE
St. Jude Donor '12
All orders have been packaged up and shipped out. If you placed on order within the last 2 days and have not received your tracking number please let me know. We have been having some issues with the tracking numbers being emailed directly from UPS.
To * Injector SPECIAL *
