NJ Guys...
My car is a H/C/I/ longtubes and high flow cats with the AIR tubes/pump removed. B&B bullets so there's no mistaking my car has work done. It's loud as hell, you can hear the cam lope clearly.
They didn't give me a single bit of trouble. All they do is bring your car in, look for any check engine lights. Turn car off. Wait 5 minutes. Turn car back on, pull forward to computer machine. Hook up to OBD-II port and scan for check engine codes (if you've been tuned like me, your tuner most likely turned off things like the rear O2's, lean codes, etc...)
So long as your car doesn't have any codes thrown, they unplug the machine, and slap on the new sticker....THAT'S IT.
No sniffer in the tail pipes, no mirror check for cats underneath, no questions asked. Just drive up, plug in, and go.
