epoxy for headlight gear replacement?
Old Jun 27, 2011 | 10:21 AM
goober51's Avatar
goober51
Default epoxy for headlight gear replacement?
I am replacing my headlight gear w/ the Brent Franker gear.The epoxy that he sent did not seem to have but a few drops of the light gold stuff(hardener?)..As I remember the last time I did this, it seemed to be a 50/50 mixture.I'm afraid it won't bond.Has anyone had any success w/ another epoxy I could buy locally? I'd like to get this back together quickly..thks
Last edited by goober51; Jun 27, 2011 at 11:36 AM. Reason: I need some help w/ this.
Old Jun 27, 2011 | 12:57 PM
NealB's Avatar
NealB
I've used this stuff several times
seems to do a good job and available at almost every auto parts store I've been in
http://jbweld.net/products/jbweld.php
Old Jun 27, 2011 | 02:13 PM
c3andc5's Avatar
c3andc5
I tried two different epoxy glues. One held for a month and one for a week. Those plastic housings were not made to pull apart although I'm sure some people have been successful. I ended up buying a new motor.
Old Jun 27, 2011 | 02:33 PM
runner140*'s Avatar
runner140*
I purchased the "kit" from rodney dickman....came complete with the two part epoxy and a popsicle stick. Its been in for over ten months....so far, so good.
Old Jun 27, 2011 | 02:42 PM
Kale's Avatar
Kale
I ended up breaking down and buying the brackets. No epoxy I used would hold.
Old Jun 27, 2011 | 02:48 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
+1 -- I used the epoxy for sealing, but installed the brackets from the get-go because I didn't expect the epoxy to hold by itself, and didn't want to hav eto do the job twice.
Old Jun 27, 2011 | 06:09 PM
goober51's Avatar
goober51
Where would I get these brackets? I may get those and/or try the jb weld..thks
Old Jun 27, 2011 | 07:02 PM
goober51's Avatar
goober51
I'm wondering if jb weld will work w/this plastic? Have u tried it on this motor? I have used it on aluminum but I don't know about this plastic, plus there's not much of a surface to work with..thks
Old Jun 27, 2011 | 07:24 PM
mjmc1273's Avatar
mjmc1273
Take three washers and slightly bend one side down on each washer, place the bolts through the washers and align the bent part of the washer over the cover of the motor, tighten your bolts down on the cover and notice the wonderful way the washers hold the the motor cover in place. Did this procedure on both of my motors and it works fine!
Old Jun 27, 2011 | 08:17 PM
goober51's Avatar
goober51
Hey, that sounds like a good idea..I'm going to do it! thks.
Old Jun 27, 2011 | 08:23 PM
C5FORFUN2's Avatar
C5FORFUN2
Same thing I did over a year ago on my DD. Still holding fine
Old Jun 27, 2011 | 08:50 PM
jornahow's Avatar
jornahow
When you say brackets are you talking about the Rodney Dickman T shaped braces?
Old Jul 19, 2011 | 12:03 PM
MrLeadFoot's Avatar
MrLeadFoot
JB Weld will not hold. It will not adhere to the plastic, which is really a nylon. That's why you're having problems. The epoxy that come with the Rodney Dickman kits are specifically designed to work with nylon, while JB Weld is not.
Old Jul 19, 2011 | 12:33 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Rodney Dickman has those bracket. I highly recommend them if you don't want to do the job twice.
Old Jul 19, 2011 | 09:50 PM
goober51's Avatar
goober51
I used the bent down washer trick. It worked great.
Old Jul 19, 2011 | 10:05 PM
SG Lou's Avatar
SG Lou
This is an EFFIN great idea !
Old Jul 20, 2011 | 01:02 PM
goober51's Avatar
goober51
that's what i thought,especially since it seemed to work so well..it helps to get the right size washers that are also thin enough to bend easily..
To epoxy for headlight gear replacement?
