sirius fiasco
Old Jun 27, 2011 | 12:14 PM
paldogy's Avatar
paldogy
Default sirius fiasco
Purchased a Starmate 5 yesterday. Won't work, tried many antenna locations, spoke to Pakistan once and then two women I could not understand, was put on hold for 20 minutes 3 times, finally canceled it this morning after another 20 minutes. Good riddance. "Your call is important to us." What has happened to this world?
Old Jun 27, 2011 | 12:24 PM
jrose7004's Avatar
jrose7004
I put my antenna up on the dashboard on the passenger side up by the windshield and my reception is fine.
Old Jun 27, 2011 | 12:51 PM
Rob04C5LM's Avatar
Rob04C5LM
Sorry to hear about the problem. I've been both a Sirius and XM subscriber for about 7 years now with 5 different receivers and have never had an issue with getting a signal or dealing with their customer service folks.
I suspect that it may be something else in the setup that's causing your problem - too bad their tech support hasn't been more helpful too you You might check with the store you bought the Starmate from - they may be able to help.
Old Jun 27, 2011 | 01:07 PM
C5 4me's Avatar
C5 4me
I got 2 lifetime contracts with my 2 units,Did you try online?
Old Jun 27, 2011 | 01:31 PM
El original's Avatar
El original
I also have sirus radio and had issues untill I discovered the antenna jack was not plugged in properly..you may want to try this it is a very stiff connection and must be aggressively pushed into the base housing even though you think it is plugged in it is just on the edge. ( surprised me too) Good luck and sirus customer service is a long wait in my experience. Greetings, Rob
To sirius fiasco
