Hood, bottom door lights
Old Jun 29, 2011 | 06:51 PM
C4Boi's Avatar
C4Boi
Default Hood, bottom door lights
The hood lamp and inside door exit lamps do not laminate when hood is open or doors are open.
Question where is the switch located under hood for it's lamp. I checked for voltage at lamp 0vdc.
Not quite sure what's going on with the exit door lamp
All could be a fuse, I don't have any reference manuals, only owners manual.
2002 Corvette
Old Jun 29, 2011 | 07:53 PM
65GGvert's Avatar
65GGvert
If you mean the door REFLECTORS don't ILLUMINATE, they shouldn't. They are reflectors. There are no exit lamps.
The hood lamp may be a bad bulb, the switch that senses the hood position, or the connector plug. I don't have the fuse number handy, but it seems like I recall that other things are on the hood lamp fuse. I'll try to look in a while to see if I can find a fuse number.
Old Jun 29, 2011 | 08:00 PM
65GGvert's Avatar
65GGvert
Or fuse 2 in the passenger footwell. I'd try the connectors and bulb first, but it could be a several things.
Old Jun 29, 2011 | 08:01 PM
C4Boi's Avatar
C4Boi
I suspect hood open switch because with hood one no voltage at bulb. Where is this switch or it's activator?
Old Jun 29, 2011 | 08:39 PM
The light fixture itself is the switch - it is a mercury type switch that goes on/off depending on if the hood is open or not. Check to make sure you have voltage at the connector located on the right side of the radiator shroud about halfway down the shroud - you'll see the connector and wires running up under the hood insulation blanket.
Old Jun 29, 2011 | 08:54 PM
65GGvert's Avatar
65GGvert
Yeah, what he said. Also check the connector by disconnecting it and make sure the contacts are not corroded.
Old Jun 29, 2011 | 08:56 PM
dougbfresh's Avatar
dougbfresh
Many people disconnect the light harness lower in the engine bay for some weird reason.
Old Jun 29, 2011 | 09:02 PM
C4Boi's Avatar
C4Boi
OK, it's dark now so I'll continue tomorrow with all suggestion. A big thanks on the mercury switch.
Old Jun 30, 2011 | 10:45 AM
Power Hawk's Avatar
Power Hawk
The light under the hood of my '03 does not work either. I was told that lots of people disconnect those lights due to not wanting them on while hood is open during a car show.
Old Jun 30, 2011 | 11:08 AM
dougbfresh's Avatar
dougbfresh
It's a silly reason anyway-the light will turn off in 10-15 minutes by itself.
To Hood, bottom door lights
