Never, ever again
Old Jul 5, 2011 | 04:14 PM
mtndv8's Avatar
mtndv8
Default Caution, slight thread detour ahead...
Patches,
Thanks for the write up, very thorough and informative, as usual...
So Cal heat aside I noticed your rocker arms and I was wondering if you had engine mods that contributed to deciding to go the dewitts retrofit? (cam, heads, etc...?)
Old Jul 5, 2011 | 04:21 PM
Patches's Avatar
Patches
Yes, Michael. I have those mods and more that contribute to the heat created by the engine. It's never run outside the limits of the factory specs but it's hotter here than anywhere I've driven it so no point pushing my luck.
Old Jul 5, 2011 | 04:36 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Wow, glad it all worked out and we did mine during the build so all was out at the time for an eaiser install
Old Jul 5, 2011 | 07:25 PM
Patches's Avatar
Patches
Fixed the last bits - did an idle relearn this afternoon and picked up a new Optima Yellow Top battery to replace my 9-year-old Red Top, R.I.P. Hope this new battery serves me as well as the last and the Red Top in the wife's C5. The Red Top I handed in as a core looked brand new still.
Old Jul 9, 2011 | 03:08 AM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Are you experiencing much of a reduction in coolant temperature with the Dewitts unit installed? I am contemplating the purchase myself.
Old Jul 10, 2011 | 01:33 PM
rdwiv's Avatar
rdwiv
Looks like you kept the factory fans - any reason you did not want to go with higher flowing aftermarket fans? Just curious....
congrats on the mod!
Old Jul 10, 2011 | 01:57 PM
Patches's Avatar
Patches
Haven't tested it to the extreme yet - I hope to be out and about next weekend with it and will report how well it does. It's very hot here and should be an excellent test. I also dropped in a new 180 deg. Hypertech stat yesterday.
I wanted to see if the stock fans could supply enough air with the double-capacity radiator and if an aftermarket fan is needed. DeWitts said it's not really required if you are not racing which I'm not. My temps have always been within factory spec - this mod was for the increased ambient temps here and for insurance.
Old Jan 18, 2018 | 01:11 PM
hatewhatownsyou's Avatar
hatewhatownsyou
since all the main details are in this post:
Has anyone bought the c6 bypass setup, cut the hardlines off and drilled/tapped for NPT fittings so soft lines could be used?
would this not be possible?
Old Jan 18, 2018 | 01:22 PM
Shaolin Crane's Avatar
Shaolin Crane
You'd probably be better off buying the improved racing version, would probably be cheaper and definitely a much cleaner install.
Old Jan 18, 2018 | 01:41 PM
hatewhatownsyou
Improved racing version? what chu talkin bout willis?
Old Jan 18, 2018 | 02:05 PM
Shaolin Crane
I'm assuming you're talking about using the bypass for a similar purpose.
http://www.improvedracing.com/oil-co...nes-p-209.html
Old Jan 18, 2018 | 02:12 PM
hatewhatownsyou
OOO I didn't realize that was the brand name, i want the bypass valve style for the oil restriction issues flowing through a radiator cooler.
Old Jan 18, 2018 | 05:03 PM
  #33
garrettg's Avatar
garrettg
While the install is not fun, undoing the drivers side motor mount and lifting that side of the engine with manifolds off there is enough room to install the c6 style lines on a c5. The lines aren't really designed to be pushed or pulled much so opening up that space helps greatly.
