Scissors jack?
Old Jul 6, 2011 | 09:27 PM
toughshift's Avatar
toughshift
Default Scissors jack?
Why doesn't somebody market a decent low profile scissors jack? You know, something you could toss in the trunk for when you wake up in the morning and have a flat tire. You get out that scissors jack and take care of business. They are standard equipment on other cars. Why can't they market one for Corvettes? OK, so you can buy a $250 hydraulic that weights 100 pounds and put THAT in your trunk. Am I missing something? Is there one available? I just saw one on Walmart that has a minimum height of 4 inches. I guess that would work if you first drove up on a couple of 2X12's. Whadda ya think gang?
Old Jul 6, 2011 | 09:39 PM
BitViper's Avatar
BitViper
there ws a post here a weekor so ago... "California Car Cover" I think has one.. but it was 180 bucks
Yep... here ya go
http://www.calcarcover.com/product.aspx?id=231
Old Jul 6, 2011 | 09:46 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
15 bucks for a low Nissan jack I bought.
Old Jul 6, 2011 | 09:52 PM
DangerBrian's Avatar
DangerBrian
Harbor Freight has one for $20 and says min is 3 3/8" - item# 66907. I'd look at it first, HF is good for some stuff, but I choose wisely when buying tools, guns and other things that my life may depend on - just passing it along
Old Jul 6, 2011 | 10:07 PM
Will have to check that one out.
Old Jul 6, 2011 | 10:34 PM
toughshift's Avatar
toughshift
SDZ06Driver....That one from calcarcover is a dandy.....a little pricey.
Old Jul 6, 2011 | 11:05 PM
Z06ster's Avatar
Z06ster
I've actually ordered the CA Car Cover jack. I should receive it next week and I will probably make a separate thread after I receive it to share my opinions...
Old Jul 6, 2011 | 11:23 PM
moserbe's Avatar
moserbe
The one from my old Pontiac G6 or my even older 87 Camaro Iroc work just fine and I have it in the rear compartment along with a portable compressor and tire repair kit. So WHAT is the problem here??????
Tom Hudson's Avatar
Tom Hudson
I went to a import wrecking yard and ask the guy if he had any scissor jacks - he looked at me like I was nutz - then said follow me - he had two 55 gal drums full of them - I bought a couple of them - 10 bucks each -
Old Jul 6, 2011 | 11:35 PM
Hammer99's Avatar
Hammer99
BMW 3 Series jack.
Old Jul 6, 2011 | 11:45 PM
cdkcorvette7's Avatar
cdkcorvette7
I did the same thing while I was looking for a horn for my truck... they had a ton of them. Five bucks a piece...
Old Jul 7, 2011 | 07:46 AM
johnson-rod's Avatar
johnson-rod
PT Cruiser jack. Comes in a pouch and the handle fits our lug nuts. Cheap and plentyful.
Old Jul 7, 2011 | 03:28 PM
voda1's Avatar
voda1
Any wrecking yard will do.
Old Jul 7, 2011 | 06:04 PM
hotwheels57's Avatar
hotwheels57
In a recent thread on the same topic, I posted the CALIFORNIA CAR COVER COMPANY jack image above. It's expensive, but it's capable of collapsing down to 1.5" and lift 2000#.
If that's out of your budget range, find a Mazda RX7 or Porsche aluminum scissors jack. They're light weight and will collapse down to 3.5" if I remember correctly. Some have a small nub on top which may mate up to the perimeter jacking points w/ minor modification.
I got mine from EBAY about five years ago for less than $30. They're usually listed there in the range of $35-50 with the cranking handle included. They look like this...
If a tire is completely deflated you will also need a small air compressor (Z06 or SLIME) to inflate the tire to provide sufficient space for the jack.
And a space saving lug wrench can be found at GORILLA (lug nuts)...
http://www.gorilla-auto.com/power.wrench
Old Jul 7, 2011 | 06:13 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
autobarn has the hydraulic scissor jack...no cumbersome wrist work...I use 2 on my lift....it goes real low and rated at 2200 lbs...built like a brick sheethouse.
Old Jul 7, 2011 | 06:26 PM
toughshift's Avatar
toughshift
I found a 2004 Pontiac GTO jack on ebay, thanks to a tip from another of our members. It looks like it'll work well. Thanks for all of your suggestions. What a great forum !
Old Jul 7, 2011 | 07:58 PM
guido7834's Avatar
guido7834
Aaa!:d
To Scissors jack?
Old Jul 7, 2011 | 11:24 PM
robert123's Avatar
robert123
My neighbor gave me a scissor jack from an old car which works great. I can even use a hockey puck with it with no clearance problems.
Old Jul 7, 2011 | 11:31 PM
GGEENN's Avatar
GGEENN
I have one from a mustang i used to own if you want it i can sell it to you like for $10 PM me
Old Jul 8, 2011 | 12:46 AM
Blown_2001Z06's Avatar
Blown_2001Z06
I have used the nissan low profile jacks. It has a nut on the end of it. I hit it with the impact gun and the car is in the air in a couple of secs. It at least gets it high enough to get a proper jack under the cradle to get it up high enough for decent jack stands.
