[Z06] Changing Z06 diff oil
Old Jul 9, 2011 | 06:58 PM
striper's Avatar
striper
Default Changing Z06 diff oil
I couldn't find any info. I'm wondering what others have used to replace the differential oil and additives if necessary. I'm thinking of changing it tomorrow once I decide.
Old Jul 9, 2011 | 07:01 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
http://www.southerncarparts.com/corv...nge-ex-43.html
I used the ACDELCO/GM fluids.
Old Jul 9, 2011 | 09:26 PM
MTPZ06's Avatar
MTPZ06
Should be lots of threads on this as well as trans fluid. Royal Purple or Amsoil 75-90, and still add the GM limited slip additive even though they both say you don't need to. Just a little added insurance.
Old Jul 10, 2011 | 09:18 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I use Amsoil Severe Gear 75W-90 and their Limited Slip additive. No issues at all for over two years.
Old Jul 11, 2011 | 07:40 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I wrote a procedure on my web site.
http://mysite.verizon.net/res0aae8/webpage.html
Scroll to the bottom for the link to various C5 stuff I wrote.
Toque
Old Jul 13, 2011 | 10:12 AM
diddiyo's Avatar
diddiyo
this is the page I will be checking out this weekend when I'm chaning my diff oil. thanks toque!
oh and i also bought amsoil.
Old Jul 13, 2011 | 10:41 AM
Toque's Avatar
Toque
Your welcome. The Amsoil seems to be working fine for me.
Good luck !
Toque
Old Jul 17, 2011 | 11:31 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Toque's writeup is very helpful.
For a direct link to the fluid AMSOIL recommends and I use in mine:
AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
AMSOIL Slip-Lock Differential Additive (Product Code ADATB)
AMSOIL Hand Pump (Product Code G2039)
Note that the Severe Gear 75w90 comes with friction modifier already in it and for most C5/C5 Z06 diffs adding extra additive is not normally needed to prevent diff chatter. I don't use extra additive in mine. Some, such as Toque, chose to add extra additive. Won't hurt the diff to add extra additive and this may turn out to be a decision of convenience. My normal advice is not to add the extra additive with the fill. If the diff does chatter, then add a few ounces of the additive. The Slip Lock comes in a tube with a long nozzle and it would be easy to open the diff fill plug and squirt in a few ounces of the Slip Lock to a full diff without having to drain and replace your fluid.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jul 17, 2011 | 12:39 PM
enigma94's Avatar
enigma94
i've been using amsoil for 3 years in my diff with no extra additive as well and never had an issue with chatter.
Old Jul 17, 2011 | 07:01 PM
lbarnard's Avatar
lbarnard
I used Torco gear fluid and GM posi-additive- my car has been on track a lot with this combo and no issues
Old Jul 19, 2011 | 09:12 PM
diddiyo's Avatar
diddiyo
i just changed mine today. pretty straight forward, leveling the car was the biggest problem for me did it as best as i could. again, many thanks to toque for his great walk-through!
holy crap does that old rear diff fluid smell terrible... uaaaargh.
Old Jul 21, 2011 | 02:57 AM
striper's Avatar
striper
I was all set to use the GM fluid. At the last minute I spoke to an engineer at Royal Purple and asked some info on their fluid. I wound up using the RP Maxgear 75-90. It needs no additional additive. I know everyone will think I must be on drugs but the diff seems quieter and smoother running, even though I didn't notice any noise before. It still seems quieter like no gear hum at all. I don't know exactly how long since the last fill but mine was a little stinky coming out too.
Old Jul 21, 2011 | 04:29 AM
SCM_Crash's Avatar
SCM_Crash
+1
I'm using the same stuff... 16K miles and going good.
Old Jul 22, 2011 | 03:09 AM
C5_Z06's Avatar
C5_Z06
Is there supposed to be a washer/gasket on the drainplug? Mine had a washer when I changed the oil and I haven't seen any comments about that in the DIY threads. So, washer or no washer?
Old Jul 22, 2011 | 10:32 AM
striper's Avatar
striper
I changed all my drain plugs to magnetic plugs. There should be a washer that is integral with the drain plug.
Old Jul 22, 2011 | 04:02 PM
C5_Z06's Avatar
C5_Z06
Can you post a picture? The diff drain plug on my car does not have a built in washer/gasket (like the engine plug has). It's just a flat surface, hence my question about the washer. I know the diff oil was changed before I changed it and I'm pretty sure the plug is the OEM one.
Edit: Plug is idential to the one in Toque's guide. The washer on my car was a separate one.
Old Jul 24, 2011 | 06:33 PM
Techsan's Avatar
Techsan
I followed exactly what Toque had written up, and I have been really happy with it.
To Changing Z06 diff oil
Old Jul 25, 2011 | 12:44 AM
striper's Avatar
striper
I'm sorry but I won't be able to post a picture of my drain plug since it is presently occupied holding the diff oil in. However, as I mentioned it is a non-stock magnetic plug so maybe that's why it is different. The washer is loose but captured in the threads so that it can't be removed. I believe I got from Eckler's a long time ago.
Old Jul 29, 2011 | 04:24 PM
C5_Z06's Avatar
C5_Z06
So with a stock drain plug, washer or no washer? Come on guys, you must have been changeing that oil a thousand times and have got to know the answer.
Old Jul 29, 2011 | 04:29 PM
Toque's Avatar
Toque
There was no washer on mine that I remember. Only done mine once myself though.
Toque
