AC issue
Old Jul 14, 2011 | 09:33 PM
OldGuard's Avatar
OldGuard
Default AC issue
AC issue
Tonight while on a ride with the wife, there was hot air comming out of the passanger 2 vents instead of AC. The driver's side and the middle vents had plenty of AC comming of them. We stopped for dinner and after dinner when we started the car up the AC was working fine on both sides. We had no other problems with it the rest of the ride. Has anyone ever had deal with a problem like this? I don't know if this was just a burp with the controls and this will never happen again or if I'm going to be in for a real problem down the road.
Old Jul 14, 2011 | 10:49 PM
dmarkshark's Avatar
dmarkshark
I would check your DIC and see if it threw any codes.
Old Jul 14, 2011 | 10:57 PM
C5-1's Avatar
C5-1
The same thing happened to me just a couple of weeks ago. Check your DIC...most likely you will have a code on the HVAC. Reset them and the problem should go away. If it doesn't go away I have also read in this forum that it could be a result of a bad ground.
To AC issue
