horn does not work
Old Jul 16, 2011 | 12:21 PM
car48nut's Avatar
car48nut
Default horn does not work
Just bought the car and the horn doesn't work. It will not honk with the pad or the key fob. Where would you look first? Perhaps someone would know the fuse number? Thanks
Old Jul 16, 2011 | 12:45 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Sorry I don't know the fuse number but that is the first thing to check. I would check to see if they are even hooked up as well. If they are then I maybe try and find one that you could hook up that you know works and try that.
Old Jul 16, 2011 | 12:50 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
just use your finger
if the fuse is OK you may wanna check and see if the relay is missing in the fuse panel under the hood as well.
Old Jul 16, 2011 | 07:58 PM
car48nut's Avatar
car48nut
It was the relay. Car did not have one for the horns. Put one in and they work. Now I wonder why the relay was taken out.
Old Jul 16, 2011 | 09:37 PM
pewter99's Avatar
pewter99
I could venture a guess but
Old Jul 16, 2011 | 10:28 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Maybe the previous owner was just not the horny type and had it removed .
To horn does not work
