Gas gauge
Old Jul 18, 2011 | 10:10 AM
charlie green's Avatar
charlie green
2nd Gear
Default Gas gauge
I have a 1998 corvette, tank full of gas. After I have driven for about 30 miles or so, the check gauges light comes on and the gas gauge will go to empty and the low fuel message will appear. All the other gauges are working fine. I have to stop the engine and restart before the gauge will work again, any suggestions with what is happening. Thanks
Old Jul 18, 2011 | 10:17 AM
ricknyc23's Avatar
ricknyc23
Throw in a bottle or two of Techron. Common problem, search the forum.
steele11's Avatar
steele11
This happened to me recently as well. I've read that Techron fuel system cleaner will help clear up the problem. The 2 times it has happened to me my wife filled up with Shell gas. All the other fill ups have been with Sunoco and never an issue.
Old Jul 18, 2011 | 10:37 AM
charlie green
2nd Gear
Old Jul 18, 2011 | 11:29 AM
jrose7004's Avatar
jrose7004
I'd go over to the C5 Tech Forum. Do a search for C5 Gas Gage problems and you'll see that it's a common C5 problem.
Old Jul 18, 2011 | 12:14 PM
rebelheart's Avatar
rebelheart
A common problem for all makes and models!If you can't find Techron,try SeaFoam.
Old Jul 18, 2011 | 12:47 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Just go with SEAFOAM...It works best and will clear all the build up in your fuel system.
Old Sep 17, 2019 | 10:01 PM
Johnny Hardcore's Avatar
Johnny Hardcore
Follow suggestions above on the fuel additive. Only run quality high octane fuel...and in the interim, if it happens again, you can run your error codes through the ondash computer and reset the error code without having to pull over to reycle the motor. Gauge will be returned to proper reading.
Old Sep 18, 2019 | 07:37 AM
The above is solid advice. Members have reported that adding a bottle of Techron Concentrate to a tank of gas, and repeating if necessary, can help remove sulfur deposits from the sending units and restore the gas gauge to working order.
If that doesn’t work, it may be necessary to replace the sending units.
Old Sep 18, 2019 | 10:44 AM
FYRARMS's Avatar
FYRARMS
Necropost!
I am going to guess that the OP fixed his fuel gauge problem 8 years ago when he made this thread. The guy hasn't been back in 6 years, so he must not like us anyway.
"Last Activity: 05-14-2013 12:15 PM"
Old Sep 19, 2019 | 09:08 PM
Johnny Hardcore
Hahahaha! Great catch! How in the heck did it get on page 1 of Gen? I missed that by a long shot.
Old Feb 17, 2020 | 12:01 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Will the long neck Techron bottle work without the funnel ?
Old Feb 17, 2020 | 12:21 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
yes
Old Feb 17, 2020 | 12:32 PM
50th year's Avatar
50th year
Originally Posted by Yello95
yes
Thx
Old Feb 17, 2020 | 08:10 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Thx
To Gas gauge
