Active handling TC not working
Old Jul 19, 2011 | 02:08 PM
jiujitsu77's Avatar
jiujitsu77
Default Active handling TC not working
Long story I pulled my wheels off to paint my calipers and now my traction control and active handling no longer work. Can anyone help
Old Jul 19, 2011 | 02:14 PM
stockpile's Avatar
stockpile
Default pull the code?
Did you pull the code? Turn your key to the "on" position.... Hold the options button down and press the fuel button 4 times within 10 seconds to enter diagnostic mode.
There is a thread here somewhere that gives more detail on how to maneuver around in dignostic mode. Pulling the code is the first thing you need to do though.
Old Jul 19, 2011 | 02:17 PM
stockpile's Avatar
stockpile
Found it...
http://www.c5help.com/c5_dtc_codes.htm
Start here, this should help you find a code that should help you figure this out.
Old Jul 19, 2011 | 02:19 PM
dougbfresh's Avatar
dougbfresh
Are you getting warnings on the dash or the DIC?
lucky99's Avatar
lucky99
Check the wheel speed sensors they may have come unpluged.
Old Jul 19, 2011 | 02:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Old Jul 19, 2011 | 02:57 PM
jiujitsu77's Avatar
jiujitsu77
i checked the codes
C1214 Sol Valve Relay Contact or Coil CKT Open
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
everytime i start it i get a service active handling, and service abs warning on the DIC and my ABS light is on.
Nothing happens when i push the TC button
Old Jul 19, 2011 | 03:08 PM
dougbfresh's Avatar
dougbfresh
Looks like your front wheel sensors got whacked-check the plug at the wheels. The 1214 will shut off the AH/TC, see if you can get the 1221/1222 to go away 1st.
Old Jul 19, 2011 | 03:34 PM
jiujitsu77's Avatar
jiujitsu77
I am embarrassed to say this but I used a spray can to paint the calipers. Do u think that the sensors may have a little paint in them? The abs and ah stopped working the day after I painted the calipers
Old Jul 19, 2011 | 04:06 PM
dougbfresh's Avatar
dougbfresh
Probably got paint on the sensors themselves. Pull the rotors off and take a look around!
Old Jul 19, 2011 | 04:27 PM
stockpile's Avatar
stockpile
The sensors are VERY sensitive. Ever since I switched from wagon wheels to a much more open wheel, I have to be extra careful when driving through dirty roads. For example, I drove through a construction zone where I could hear gravel and chunks of soot flying around. Sure enough, my AH TC system shut off. All I needed to do was wash the car and give the hubs / wheels a good dousing, and I was fine. Same thing happened another time when I drove on a road with freshly melted snow, leaving salt and cinder all over the road. Sensor got dirty, threw a code, but was resolved by a good cleaning.
If that's not it, check your fuses and like someone else said, check the plug a the wheels.
Old Jul 19, 2011 | 05:42 PM
jiujitsu77's Avatar
jiujitsu77
I am going to try that asap. Thanks a lot.
To Active handling TC not working
