Quick question for those running l5's
Old Jul 21, 2011 | 02:26 AM
BHRZ06's Avatar
BHRZ06
Default Quick question for those running l5's
Is it normal for the passenger side quarter panel to be almost a inch wider than the drivers side? how did you remedy this if its a common issue? I don't want to spend too many hours prepping these if its a defect.
Uploaded with ImageShack.us
Old Jul 21, 2011 | 02:37 AM
White Rabbit's Avatar
White Rabbit
So the flare is actually 1 inch wider?? Call the company, might just have to send it back.
Old Jul 21, 2011 | 02:42 AM
BHRZ06's Avatar
BHRZ06
Yes check out the pics and the size of the flares i just wanted to see if this is normal (aftermarket fit)or if it is a defect
Old Jul 21, 2011 | 07:43 AM
tracer1's Avatar
tracer1
Tell 'em to send one to match the pass. side & you can run wider tires, I guess.
tracer1
Old Jul 21, 2011 | 09:58 AM
Dominic Toretto's Avatar
Dominic Toretto
Since the factory panels match, it is my understanding that the aftermarket panels should match as well.
-Alex
Old Jul 21, 2011 | 10:12 AM
jdmvette's Avatar
jdmvette
Night Owl for life
No that is not normal. Call them because they do make custom flares to any width you choose and it looks like you got one that was made to be more narrow than the standard 2".
Old Jul 21, 2011 | 10:28 AM
BHRZ06's Avatar
BHRZ06
Thanks man will do I just wanted to be sure because it suprised me quite a bit.
To Quick question for those running l5's
