[Z06] Need Torque Spec. Please Help!
Old Jul 21, 2011 | 06:08 PM
yellowLPEZO6's Avatar
yellowLPEZO6
Default Need Torque Spec. Please Help!
Would one of you ZO6 owners that has a service manual , please check the torque spec. for the REAR LOWER CONTROL ARM CAM BOLT NUT that is used to adjust wheel camber. I have a 2003 ZO6.
This would be the lower comtrol arm bolt nut to the front , that is closest to the driver.
Thank you so much in advance for your help.
All The Best,
yellowlpezo6
dwparrish2003@yahoo.com
Old Jul 21, 2011 | 06:17 PM
speedyhawk101's Avatar
speedyhawk101
When in doubt German Torque will do the trick. The German spec: Gutentight
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
Lower Control Arm (Fr) Cam Bolt Nut 145 N·m 107 lb ft
Lower Control Arm (Rr) Cam Bolt Nut 95 N·m 70 lb ft
Lower Control Arm Ball Joint Stud Nut (1st Pass) 20 N·m 15 lb ft
Lower Control Arm Ball Joint Stud Nut (2nd Pass) 3 ½ flats
Lower Control Arm Ball Joint Stud Nut (Final Pass) 70 N·m 52 lb ft
Old Jul 25, 2011 | 12:58 AM
Blown_2001Z06's Avatar
Blown_2001Z06
Knew I saved this for a reason
File Type: pdf
To Need Torque Spec. Please Help!
