service column lock
Old Jul 24, 2011 | 07:40 PM
Jim.carbone's Avatar
Jim.carbone
Default service column lock
I got in my 2000 FRC today
Had the message - service column lock.
I hit "reset"
message went away.....
The car drives fine.......i get the message each time i start the car now...i hit reset and it goes away.
Can I keep driving it?
Old Jul 24, 2011 | 08:10 PM
Gitusum's Avatar
Gitusum
I hit "reset"
I would take it and get it looked at. the last thing you want is to be stuck in a parking lot or something because your car will start but cant turn the steering wheel Happened to a friend of mine and it wasnt pretty
Rick
Old Jul 24, 2011 | 09:05 PM
FYRARMS's Avatar
FYRARMS
I'm sure this has never been discussed before...
Old Jul 24, 2011 | 09:06 PM
FYRARMS's Avatar
FYRARMS
79 pages of reading, but people still ask about it. LOL
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Jul 24, 2011 | 09:08 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Check your battery, may be time for a replacement. Low batteries will often trigger that message. As a precaution I recommend purchasing and installing a Column Lock Bypass:
Here are some helpful links....
How to install a Column Lock Bypass:
http://97vette.com/howto/columnlock/index.html
http://www.ls1howto.com/index.php?article=24
You can get a CLB Kit from either of these vendors:
http://www.corvettesofhouston.com/pr...e9bf70207aef69
http://www.thunderracing.com/catalog...d=220&pcid=156
Steering Column Lock FAQ's:
Old Jul 25, 2011 | 09:29 AM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Maybe OP could just print all 79 pages and keep them in the car so he has something to do when he's stranded with a locked steering wheel waiting on a wrecker?
Then comes the "shoulda, woulda. coulda" syndrome!
Old Jul 25, 2011 | 12:43 PM
mfile2000's Avatar
mfile2000
Don't you think everything has already been discussed here? The guy is looking for help. Not everyone can turn a wrench or keypunch their way through a help forum.
Old Jul 25, 2011 | 01:00 PM
Jet-Jock's Avatar
Jet-Jock
Watch the video parts 1 & 2: Video
Old Jul 25, 2011 | 01:02 PM
jvette2's Avatar
jvette2
Have your car looked at, I had the SERVICE COLUMN LOCK message last week in Spearfish South Dakota. I already had the first recall done on the column lock. This time the car would not go over 2 miles an hour, reset the message disconnected the battery and restarted the engine. Same message and car would not go over 2 mph, so this time I put in a new batttery, same result. After speneding an extra night in a hotel took car to dealer in Spearfish and they ordered new column lock, they had none in stock, part had to be sent UPS. Long story short with the cost of getting the car fixed, extra night in hotel, rental car for over a week and misc. expenses I spent over 2 grand. Read the other posts and get your car in a shop, if I had only put the bypass on the car I could of saved alot of money.
Old Jul 25, 2011 | 07:00 PM
FYRARMS's Avatar
FYRARMS
No, but if they can start a new thread, they can read a sticky located at the top of the Tech section. I was nice enough to provide a direct link for him since he didn't see it.
Old Jul 25, 2011 | 11:46 PM
Baldfart's Avatar
Baldfart
Is it possible to remove the lock plate in the column and replace it with the plate they put in the automatic cars that were included in the early recalls for the automatics?
Old Jul 26, 2011 | 12:10 AM
C5-1's Avatar
C5-1
Old Jul 26, 2011 | 12:17 AM
3rd_Vette's Avatar
3rd_Vette
Old Jul 26, 2011 | 07:26 AM
Jet-Jock's Avatar
Jet-Jock
It's just as easy to remove the panel fascia and once the actuator retracts (key in and to ON), disconnect the power cable from the actuator.
Problem is, there is more to the issue then just the "locking" of the steering wheel. The computer needs to know that a certain voltage is present and that the actuator successfully unlocked the column. That's where the CLB (bypass) module comes into play. It sends the appropriate signal back to the computer, thus allowing the system continue with the start and run sequence.
(To change the lock plate, you'd have to disarm the SRS, then disassembly the steering wheel, then remove the steering wheel (requires a puller), then access the lock plate and replace it with the new plate made available during the recall, replace and re-assemble everything.)
To service column lock
