From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you have the original style water pump - the thermostat is sold as a part of the assembly (in the neck). When you purchase a new thermostat, it comes in the neck.
If you upgrade to a 2004+ water pump, then the thermostat is a separate unit.
Just a sidenote about some aftermarket 160* stats. I bought one and soon noticed my car would reach 247* + sitting at stoplights. When I got on it under hard throttle it would sweep past 250* until I backed off and let it cool down.
I suspected the stat wouldn't open up enough to allow more coolant to flow. So I reinstalled my original 190* and the car never overheated again. Never wanted to retry another using that stat from that auto parts store. Maybe next year I'll try again with a different thermostat brand name.
Oh that 160* wasn't even 30 days old, but they did have a warranty!
definitly a defective unit. i got one from SLP and even in half an hour of traffic here in S Florida last week it didnt go above 215.
[QUOTE=blacksedan87;1578228079]If you have the original style water pump - the thermostat is sold as a part of the assembly (in the neck). When you purchase a new thermostat, it comes in the neck.
Originally Posted by blacksedan87
160* T-stats are sold in those necks, as are 180* and 190*. Just because it is a 160* do not assume that it has been disassembled.
Originally Posted by barblarry93
all i want to know is how to get the old thermo out of the neck, and the new one in!
So if I am understanding blacksedan87 correctly, he is saying that if you have the older style water pump you cannot remove the T-Stat but must purchase the water pump/neck with the T-Stat installed, or you can upgrade to the newer water pump in which case you can replace just the T-Stat in whatever degree you want. I am sure someone will correct me if I am mistaken.
