Front Plate Cover Removal
Old Jul 27, 2011 | 04:43 PM
PhilsFRC's Avatar
PhilsFRC
Default Front Plate Cover Removal
Somewhat simple question--I know the cover is secured at the bottom with two screws and a tab at the top that slips into the nose. What's the best way to get it out (installing an American Hydrocarbon screened cover) without causing damage? Pry at the upper seam with a non-marring tool to release the tab and swing out? Don't want to break something before I start. THX
Old Jul 27, 2011 | 04:59 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
You simply remove the two screws on the bottom and it will almot fall out.
Old Jul 27, 2011 | 05:02 PM
PhilsFRC's Avatar
PhilsFRC
I thought the screws were behind the cover--how do you access them?
Old Jul 27, 2011 | 05:05 PM
PhilsFRC's Avatar
PhilsFRC
OK, I got it--the screws go in from the front as opposed to down from the top (behind the cover):
http://parts.nalleygmc.com/images/pa...111Y07-028.JPG
Old Jul 27, 2011 | 05:18 PM
jrose7004's Avatar
jrose7004
Use a small screwdriver on each side at the bottom.
Old Jul 27, 2011 | 05:27 PM
Funnone's Avatar
Funnone
Old Jul 27, 2011 | 09:54 PM
That's the way mine works. You can use your fingernail to grab the bottom edge and gently pull it towards you - it will come right out.
To Front Plate Cover Removal
