Broken E-Brake....cable?
Old Jul 30, 2011 | 01:22 AM
AntsSilverC5's Avatar
AntsSilverC5
Default Broken E-Brake....cable?
Whatsup all-
Last week when I was going to a car meet, I put the car in gear and pulled to ebrake to park it and I heard a SNAP! The ebrake still "clicks" normally when I pull it, but it doesn't stop the car anymore. Even before, it didn't work that great (would only actually stop the car at the top click or two) but now it seems like its completely out. Did I snap the cable? Any idea what this could be? Easy fix?
Old Jul 30, 2011 | 01:44 AM
C5Natie's Avatar
C5Natie
You can trace the cable under the car. I'd remove the rear wheels and check the e-brake myself. Couldve broken where it connects to the rear brake set up but if it doesnt stop the car at all then it did break for sure, only question is where. Theyre not that cheap but its not too expensive. If you do your own brakes and stuff its not too difficult of a job to do, just depends what broke.
Old Jul 30, 2011 | 01:50 AM
C5Natie's Avatar
C5Natie
Just an example, parking brake shoe $82.
http://www.autozone.com/autozone/par...ier=842022_0_0_
Parking brake cable $25. There are two though, right and left.
http://www.autozone.com/autozone/par...=912849_0_6739_
Old Jul 30, 2011 | 01:07 PM
Last C5's Avatar
Last C5
Default Don't buy Raybestos e-brake cables.
DO NOT BUY RAYBESTOS cables!!!! They look good, they're well made, and they DON'T FIT. The actual steel cables are too large for the slots in the transition bracket and the holes in the outboard cable ends are too small for the e-brake lever on the back of the wheel hub.
Raybestos #s BC95515 & BC95516
Old Jul 30, 2011 | 05:57 PM
moserbe's Avatar
moserbe
That's interesting, did you find out the hard way?
Old Jul 31, 2011 | 02:24 AM
Last C5's Avatar
Last C5
I seem to learn everything the hard way.
You wouldn't want to buy a brand new Sony HRD-CX160 Camcorder would you. Just don't try to take track videos with it.
Old Aug 1, 2011 | 09:55 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I had the same thing happen to me except it was a hook that the ebrake cable hooks on to that broke.
To Broken E-Brake....cable?
