When does your automatic hit 3 rd gear does it change with year?
Old Aug 1, 2011 | 08:28 PM
zesstey1's Avatar
zesstey1
Default When does your automatic hit 3 rd gear does it change with year?
just sold 01 that hit 3 rd at 100 mph just bought a 2000 that to my suprize hits 3 rd at about 75 mph is the 01 shift points different? If so can you change the 2000 to do the same?
Old Aug 1, 2011 | 08:31 PM
killain's Avatar
killain
Oldtimer
Default Third gear ?
Mine hits 3rd gear at about 35-40 MPH, but I assume your talking about WOT? Or I missing something ? You are referring to drag racing? Too Many questions right ?
Old Aug 1, 2011 | 08:42 PM
zesstey1's Avatar
zesstey1
Sorry I quess I should have said Wfo!!! ***** out!!!
Old Aug 1, 2011 | 08:48 PM
DJ_USMC's Avatar
DJ_USMC
I havent given mine a run to 100mph in a while, but to answer your question the shift points are programable. East Coast Supercharing (forum member) tuned my computer.
Old Aug 1, 2011 | 08:51 PM
They can be programmed - Find yourself a good tuner and have them do it for you.
Old Aug 1, 2011 | 08:58 PM
zesstey1's Avatar
zesstey1
It's at the dealer getting front hub assembly abs and trac contol where on have friend that works there can they do it?
Old Aug 1, 2011 | 09:13 PM
TorchRedRocket's Avatar
TorchRedRocket
If you are talking about shifting at WOT, your '01 shifting into 3rd @ 100mph had the stock 2.73 gears, while your new '00 probably has a set of 3.42 gears swapped in (might even be 3.73?). Can you look under your differential and see if it says what gears you have?
Old Aug 2, 2011 | 03:24 PM
GeneT's Avatar
GeneT
red line with an A4 in second gear is 100 mph with a 2.73 rear end
Old Aug 2, 2011 | 04:17 PM
Steve-O's Avatar
Steve-O
after dynotune my 04 a4 makes 2 to 3 at 105mph, about 50rpm above redline.
Old Aug 2, 2011 | 07:45 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I just checked my tune for my 2002. It has 2->3 set for WOT at 75mph. I do have 3.42 gears.
You may want it to go to 100mph, but that's unwise. If it's set too high, it will bounce off the rev limiter and performance will suffer greatly.
The old car may have had 2.73 gears, which by my calculations would have it's WOT gear change set at 94mph.
Old Aug 2, 2011 | 09:04 PM
zesstey1's Avatar
zesstey1
[QUOTE=nj02vette;1578302417]I just checked my tune for my 2002. It has 2->3 set for WOT at 75mph. I do have 3.42 gears.
The old car may have had 2.73 gears, which by my calculations would have it's WOT gear change set at 94mph.[/
Now that I think about it gears make all the sense
Thanks for the input. There is just something cool about a car pulling hard to 100 mph in second gear brings back memories of the zr1 I had.
To When does your automatic hit 3 rd gear does it change with year?
