Cooling Mod
Old Aug 6, 2011 | 11:44 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Originally Posted by Must_Have_Z
I agree. And the shroud and radiator cover kinda help hold everything in place too. I just installed a Honker today, and without the shroud and cover, the radiator and cooling fans are kinda loose... Sounds a little sketchy to me!
I'm still using the radiator cover, but I'm not using the shroud. The radiator cover keeps everything in place... in fact when doing the front plate mod, you remove the shroud. If it seems sketchy to you, the search button will be your biggest friend. Removing the radiator shroud will not work with the honker.
Old Aug 6, 2011 | 11:47 PM
corvettedaddy11's Avatar
corvettedaddy11
Heres mine too..!
Old Aug 7, 2011 | 08:56 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Works well for me too and it really does get the temps down!
Thanks,Matt
Old Aug 7, 2011 | 10:20 AM
TriplBlk's Avatar
TriplBlk
I dont have this setup as Im going thru a pretty different setup. but here's what I did when I deleted the shroud. I had the C5.5 bumper to. Def a CAI with that big *** opening
Hope this shows it enough ( sorry I didnt take many pics of this setup).
Old Aug 7, 2011 | 11:05 AM
Must_Have_Z's Avatar
Must_Have_Z
That makes sense. I didn't know you had a Vararam with your setup and were using the cover. The "sketchiness" implied no shroud, no cover, and a non-Vararam filter.
Old Aug 7, 2011 | 01:47 PM
TXGS507's Avatar
TXGS507
David,, i am in Plano and seeing the same temps as you.. Glad i am not the only one... Solution... Drive my Charger!
Originally Posted by DavidFidone
Yeah pics! Im in Dallas having the same problem. Mines getting in the 230s
Old Aug 7, 2011 | 09:10 PM
C5RClone's Avatar
C5RClone
I live in Florida and I have a chip so I always run hotter than average in summer but I read about Water on a post and tried it, I've only taken the car out once since I added it but it did seem to make a difference of about 5 degrees.
Old Aug 7, 2011 | 11:50 PM
All_Motor_C5LS6
Chip?
Old Aug 8, 2011 | 01:03 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Or you can put on a Cool-It in about 10 minutes and not worry about it.
I live in Sacramento where temps over 100 are common this time of year. After installing this, my temp gauge watching days are over.
Here's the link.
http://www.saccitycorvette.com/COOLITv2.html
