speedo gone crazy "HELP"
Old Aug 6, 2011 | 03:28 PM
Ole Blaster's Avatar
Ole Blaster
Default speedo gone crazy "HELP"
Speedometer shot up to 80 mph after taking off from a light,and I know I was no way near 80 mph, maybe 55 or 60 tops.. anyone have any idea whats going on??? did a search and didnt see anything...
Old Aug 6, 2011 | 03:42 PM
TorchRedRocket's Avatar
TorchRedRocket
You don't have it set to metric, do you? Were you spinning the tires?
Old Aug 6, 2011 | 03:48 PM
Vettmann17's Avatar
Vettmann17
Sounds like you had it switched to kilometers
Old Aug 6, 2011 | 04:03 PM
TorchRedRocket
80 km/hr=50 mph
If you really goosed it in 1st gear, it would look abnormally fast and shoot up to 80 quickly if you have it set to metric.
Old Aug 6, 2011 | 04:08 PM
Ole Blaster
Thanks for the fast reply guy's,, yes the wheels did spin a bit from the take off, and I'll check to see if I set to metric by mistake because I was messing with the DIC today checking the voltage and other stuff being it's been sitting about 12 day's.. Thanks again and I will let you all know whats happening...
Old Aug 6, 2011 | 04:34 PM
Ole Blaster
Yes it was on metric I turn the key and seen KPa and yep I had to of hit the E/M button...switched it back... I will drive it later to make sure (battery charging) but has to be it... guy's I was about to go again...thank you my CF friends....
To speedo gone crazy "HELP"
