LED Reverse lights
Old Aug 24, 2011 | 12:25 PM
tonyb47's Avatar
tonyb47
Default LED Reverse lights
I installed led reverse lights on my 2000 c5 and the lights are on all the time, get brighter when I put the car in reverse, Anybody else experience this.
Old Aug 24, 2011 | 12:34 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
You need load resistors. Some C5s do it. Most (including my 99) don't.
http://www.shop.jwmotoring.com/produ...5&categoryId=4
Old Aug 24, 2011 | 12:35 PM
kris6868's Avatar
kris6868
Yeah mine are the same.
Does this cause the bulb to burn out faster?
Old Aug 24, 2011 | 04:25 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
do you have other LED lights (like the DRL or parking lights)?? adding others will sometimes create the need for additional load in the circuit. i added the reverse led lamps from jwmotoring without any problems what so ever, but other than my halo led tail lamps, i don't have any others. you can also add the anti flash harness that jw and others sells to avoid the problem no matter how many led lamps you add. i have an extra one for sale should you be interested. brand new, never installed.
To LED Reverse lights
