Key Fob not working
Old Aug 24, 2011 | 04:29 PM
redtorque's Avatar
redtorque
Default Key Fob not working
Recently, my keyless entry remote (fob) has stopped opening the driver's side door. Also, when I shut the car off only the passenger's side door automatically unlocks. I have to manually unlock the door to get out. Has anybody else encountered this issue and is it an easy fix?
Old Aug 25, 2011 | 08:43 PM
Joy of 6's Avatar
Joy of 6
I'm having the same problem. Although it is sporadic and not all the time. End up opening the door with the key
Old Aug 25, 2011 | 10:17 PM
redtorque's Avatar
redtorque
Thanks. Any ideas what is causing it and can it be easily fixed?
Old Aug 25, 2011 | 10:20 PM
Dixiecrat's Avatar
Dixiecrat
new batteries.
Old Aug 25, 2011 | 10:22 PM
(Lucy)'s Avatar
(Lucy)
Account disabled by request Dec 2015
First is your battery dead in the Key Fob
second you can go to options in your computer and select auto lock or unlock both doors or one door. When you pull the key out of the ignition both doors should unlock.
lastly check out this thread!!
http://forums.corvetteforum.com/c5-g...ogramming.html
Old Aug 26, 2011 | 09:08 AM
barblarry93's Avatar
barblarry93
Do search-its might be the door module. Most of us have had the same problem.
Old Aug 26, 2011 | 10:16 AM
sgancarz's Avatar
sgancarz
Being everything is associated with the drivers door only, I would say that you have an issue with the Driver Door Control Module (DDCM). Probably bad relays. Here is a link for DIY repair.
http://www.ronjpics.com/Corvettestuff.htm
To Key Fob not working
