[Z06] FE4 Suspension
Old Aug 25, 2011 | 08:05 PM
BLKWDWZ06's Avatar
BLKWDWZ06
Default FE4 Suspension
Do all the 2004s have the revised suspension group FE4, the one tested on the Nurburgring Circuit.
Thanks in Advance!
Old Aug 25, 2011 | 08:26 PM
tlove32's Avatar
tlove32
04 Z06......Yes
Old Aug 25, 2011 | 08:27 PM
BLKWDWZ06's Avatar
BLKWDWZ06
thanks tlove
Old Aug 26, 2011 | 01:15 PM
kerryt1's Avatar
kerryt1
Nurburgring
Old Oct 9, 2011 | 12:46 AM
BlueTeamZ06's Avatar
BlueTeamZ06
Mine's an '02 and was also tested on the Nurburgring! I think it did pretty well...
Old Oct 9, 2011 | 10:42 AM
Solofast's Avatar
Solofast
The only difference between the 04 and the earlier versions of the Z are the shocks. The shocks were changed in 04, the change was subtle, but it did improve the handling of the car. If you wanted to upgrade an earlier Z to that standard all you have to do is change the shocks.
BTW Bilstein sport shocks have the same damping curves on the front shocks and almost the same in the rear. They cost a lot less than the stock 04Z shocks and last a lot longer.
To FE4 Suspension
