[Z06] 2001 corvette suspension
Old Aug 25, 2011 | 11:49 PM
v_ballqueen's Avatar
v_ballqueen
1st Gear
Default 2001 corvette suspension
Hey everyone!
I have a 2001 Vette that I feel the suspension could use some work. It doesn't feel like its "tied" down, or "hugs", the road that well. I really don't want to have the issue cause an accident.
So I am asking for any suggestions but nothing outrageously costly either.
Thanks!
Old Aug 26, 2011 | 08:33 AM
zeke2u's Avatar
zeke2u
First, make sure you have good "ultra performance" tires, no run flats. Replace the shocks with newer C6 Z06's from Gene Culley or spend a little extra ($200) for '04 shocks. Then, get a 4 wheel alignment with Pfadt alignment spec's:
Front................... min /max
Camber (deg) ..... -0.7/ -0.9
Caster (deg) ...........7.5 /8.5
Toe................... -1/16" /0
Rear
Camber (deg)........ -0.4 /-0.6
Toe .......................1/16"/ 0
These settings provide performance and little tire wear - and new shocks should make the car feel more "tied down".
Old Aug 26, 2011 | 01:11 PM
tlove32's Avatar
tlove32
tires and alignment make a world of difference
Old Aug 26, 2011 | 04:29 PM
Oleman's Avatar
Oleman
You might want to consider the DRM Shocks as an option as well. I ordered a set for mine
Old Aug 26, 2011 | 08:03 PM
v8ophile's Avatar
v8ophile
I replaced my stock shocks around 65K with Bilstein Sport Shocks. I also replaced the plastic sway bar end links with metal links. I then lowered it slightly on stock bolts and got an alignment. As mentioned, a good set of tires will also cause a dramatic difference. A shock replacement is something a backyard mechanic can do in an afternoon.
Old Aug 27, 2011 | 01:04 AM
MTPZ06's Avatar
MTPZ06
New tires and some Bilstein Sports will be night and day.
Old Aug 27, 2011 | 11:23 AM
CHJ In Virginia's Avatar
CHJ In Virginia
You do not state a milage for your car, that would give a better idea of what might need to be done. If you have a high mile car, a complete suspension inspection would be in order. I would check the following items and replace / refurbish / upgrade as necessary based on your final goal and usage of the car. You need a firm foundation before any upgrades are attempted.
1) A arm bushings
2) All ball joints and tie rod ends
3) Sway bar bushings
4) Sway bar end links - change to metal from plastic
5) Shocks - upgrade depending on what intended usage is
6) Tires - many types available again depending on intended usage
7) Lower the car - easy to do on stock bolts
8) Alignment
the sky is the limit on upgrades based on your budget. If all the above are addressed you will have a car that handles and drives well.
Old Aug 27, 2011 | 01:40 PM
ptindall's Avatar
ptindall
Good replies here.
To 2001 corvette suspension
