PFADT Coilovers
Old Aug 29, 2011 | 04:30 PM
1SHADYZ's Avatar
1SHADYZ
Default PFADT Coilovers
I've been having issues with my PFADT Coilovers, they're making a clunking sound over bumps. I've spoke to the PFADT employees and all they told me is it shouldn't be happening and told me to go where I got them installed for them to double check them. If anyone knows how to solve this problem before I get in touch with the installers please let me know. Thank you!!!
Old Aug 29, 2011 | 04:56 PM
bumble-z's Avatar
bumble-z
Make sure that it's not the end links.
Disconnect them & see if the noise is gone.
Old Aug 29, 2011 | 06:37 PM
chargedc5's Avatar
chargedc5
Old Aug 29, 2011 | 08:14 PM
SFCVETTE's Avatar
SFCVETTE
mine did the same thing after installing them. I checked everything. Turned out the top mounting nut was not tight enough, once i tightened it up all the noises went away.
Old Aug 29, 2011 | 08:52 PM
jgump's Avatar
jgump
I would go with the top nut being loose. It only needs to be 75 IN/LBS though. Use some blue lock tite too. Tighten while the car is on the ground.
Old Aug 29, 2011 | 09:26 PM
bumble-z's Avatar
bumble-z
Be real, real carefull not over tightening those two nuts.
75 in.lbs is equivelent to only (6.25 ft.lb)
Old Aug 29, 2011 | 10:40 PM
Spoon83's Avatar
Spoon83
This seems to be a very common problem with PFADT coils. I purchased a set, put them on and noticed the noise on the right rear side. I contacted the manufacturer (customer service was great, btw) and they asked for pics. Sent over the pics and they sent me four newly designed mounts, new hardware and two rear shock bodies for replacement.
After the new hardware, the sound still continued so I decided to rule out other parts. I thought it may be my STS charge pipes hitting the rear fenders, well since then I have gone to a Novi 2000 kit and sold the STS kit. The sound is still there!!!
Then last weekend I disconnected and removed the rear sway bar, zipped tied the end links and drove the car around, and the clunking is still there.
Sorry for the long post but does anyone have different advice. I will be contacting the company soon...
Old Aug 29, 2011 | 10:56 PM
bumble-z's Avatar
bumble-z
If the front coilover shock bolts/nuts are loose, it could make a noise in the front. Or top shock nut loose.
If the top shock rear bolts come loose , or possible broken weld that holds the nuts on top of the upper mounting base,(2 on ea side) it could make noise back there.
Front upper a arm bolts loose.
Rear upper a arm bolts loose.
That pretty much covers all the areas it could be, if all the Pfadt parts are new & installed in there propper positions.
Old Aug 29, 2011 | 11:05 PM
robert miller's Avatar
robert miller
Same here will look at the nuts tomorrow and see..
Old Aug 30, 2011 | 06:45 AM
1SHADYZ's Avatar
1SHADYZ
Awesome!... I'll be sure to check everything out after work today... I'll let you know how everything goes... Thanks a lot everyone!
Old Aug 30, 2011 | 07:03 AM
jgump's Avatar
jgump
Check to see if the spring are firly seated in the perches too. They can come loose when lifting the wheel off the ground.
To PFADT Coilovers
