damaged my car
Old Aug 30, 2011 | 03:53 PM
rootpooty's Avatar
rootpooty
Default damaged my car
Im so bummed about this. I treat this car as best as I can and now this happened! I parked next to a sidewalk that had a good 3 inch rise on it and well my dumb self forgot about the ledge upon leaving and well as you can see the rocker panel found out what concrete tastes like! I took her to a body shop and was quoted almost 900 for the fix.
Old Aug 30, 2011 | 04:13 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I did the same thing to my '07. A body shop close to me was able to repair it beautifully and matched paint exactly. Mine was worse than yours. Cost was $350 and know that mine is Montery Red which is really hard to match. Looks great now.
Old Aug 30, 2011 | 04:15 PM
kris6868's Avatar
kris6868
You have a nice Vette.
Don't get to bumbed.
Something happens to everyone at some point
Old Aug 30, 2011 | 04:21 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Ouch.....but you have a beautiful C5 and she can be fixed.
Old Aug 30, 2011 | 05:32 PM
hotwheels57's Avatar
hotwheels57
"Things happen for a reason."
Old Aug 30, 2011 | 05:33 PM
kris6868's Avatar
kris6868
Well put
Old Aug 30, 2011 | 05:35 PM
Accidents do happen - sorry about the bad luck but the body shop should be able to make it look like new again. Best of luck with the repair.
Old Aug 30, 2011 | 06:22 PM
CatCam's Avatar
CatCam
Damn - that sux. Shop around for a better price to fix her.
Just a question - if the car wasn't slammed down would it have still hit the curb?
I just see a lot of folks lower the cars and then tear it up on "road obstacles"....
Old Aug 30, 2011 | 06:55 PM
ricknyc23's Avatar
ricknyc23
i suggest you get a few more estimates. that sounds high to me
Old Aug 30, 2011 | 07:04 PM
rootpooty's Avatar
rootpooty
The dealer gave me a better price today for 700. I might just have them do it. If the I car wasn't lowered I prob would've cleared it.
Thanks guys for the compliments
Old Aug 30, 2011 | 07:14 PM
fun01's Avatar
fun01
Awesome ride good luck with repairs.
Old Aug 30, 2011 | 07:17 PM
hotmerc's Avatar
hotmerc
I had the same thing happen & did it the same way. Mine was every bit as bad, mine was repaired & you can't tell that a repair was ever done. I spent about $350 for the repair. The guy that did the repair said the hardest thing about the repair was getting it high enough to work on it.
Old Aug 30, 2011 | 07:31 PM
jrose7004's Avatar
jrose7004
I've had to have the rockers fixed on mine twice. You won't be able to tell once they're done.
Old Aug 30, 2011 | 08:06 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
And I know the reason.....
Sorry about your car, It can be fixed as good as new.
Mr.Bill
Old Aug 30, 2011 | 08:09 PM
03 A/E Coupe's Avatar
03 A/E Coupe
Here's a crazy thought - perhaps it is a good time to consider the rear brake duct mod....
Good luck on the repair.
Old Aug 30, 2011 | 08:16 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Plus, now would be a good time to perhaps have the other side touched up and any other chips, etc. It's cheaper for the shop once they pull out the paint/materials to do more vs. less. You could probably negotiate a nice deal.
Your car looks great! You obviously take good care of it, so I know how much it must hurt to have a self-inflicted wound like that!
Old Aug 30, 2011 | 08:52 PM
f6john's Avatar
f6john
On the bright side, you didn't wipe out a rim in the process too!
To damaged my car
Old Aug 30, 2011 | 09:01 PM
dklowrider's Avatar
dklowrider
while they have a paint match, do the other side.
Old Aug 30, 2011 | 09:21 PM
rootpooty's Avatar
rootpooty
Im sorry I thought I mentioned it the 700 is for both sides. Drivers side has minor scratches so I figured what the heck.
Yeah I was pretty worried about the rim when I heard the scrape. Just glad nothing happened to it
Old Aug 30, 2011 | 09:42 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
That seems very high to me...the rocker area is an isolated area...meaning it has a clean break front and rear...nothing has to be blended. When I did my rear brake scoops, I had the paint shop do both sides for 150 dollars.. that hit is just a little epoxy, some sanding and some paint and its just one side...
I wouldnt pay more than 250 to get that fixed.
I did this myself and never did body work before... I could fix that hit in two hours.. 900 dollars is insane. the shop that painted my rockers, also painted my MCM hood, did a perfect job with a perfect match for 500 dollars.. I suggest you look around. You dont want a new rocker, you just want it repaired.. 900 dollars would be the cost to remove the old glued on racker and replace it with a new one... there is about 800 in labor just to remove the rocker and put on a new one... which is not the way to go.
I had a local paint shop paint both rockers for 150 dollars.
