help
Old Sep 2, 2011 | 09:15 PM
dj00vette's Avatar
dj00vette
4th Gear
Default help
can someone tell me how to access the instrament fuse box in my 2000 coupe? My service column lock error has activated and i am trying to pull fuse 23.
Old Sep 2, 2011 | 09:16 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
the panel on the passenger floorboard?
Old Sep 2, 2011 | 09:26 PM
dj00vette's Avatar
dj00vette
4th Gear
I believe so. IDo I need to remove the left foot support and or the gas pedal block to remove the carpet to uncover the fuse box?
Old Sep 2, 2011 | 09:33 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Passenger side, Just slide up the carpet piece at the end of the floor board, It will lift right out.
Old Sep 2, 2011 | 09:43 PM
dj00vette's Avatar
dj00vette
4th Gear
so next dumb question...I am in the box, is there an easy safe way to pull out the fuse without damaging them?
Old Sep 2, 2011 | 09:48 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
fuse puller or needle nose pliers.
damilleniumboy's Avatar
damilleniumboy
Get a pair of needle nose pliers if you don't have a fuse fuller. That will do the work a whole lot more efficiently.
Old Sep 2, 2011 | 09:49 PM
damilleniumboy
There is a fuse puller in the fuse box inside the engine bay next to the battery. Just unscrew the lid and the fuse puller should be in the middle of the fuse box.
Old Sep 2, 2011 | 09:54 PM
dj00vette's Avatar
dj00vette
4th Gear
well i pulled the fuse and waited @ 30 seconds put it back in and my service column lock problem did not go away. Any words of wisdom for other things to try?
Thanks for the previous help!!!!!
Old Sep 2, 2011 | 11:30 PM
cdkcorvette7's Avatar
cdkcorvette7
Probably the most common issue these cars have... http://forums.corvetteforum.com/c5-t...ky-please.html
Old Sep 3, 2011 | 12:04 AM
shadowman1's Avatar
shadowman1
He'll be busy reading for a while.
Dave
To help
