Engine temp
As long as the temp goes back down when you get the car moving again, it's not too hot at 230 while sitting in stop and go traffic.
Your temps at cruise should be around 194-198, stopped idling with ac on around 198-201, and with ac off it will get to about 230 when the fans kick on and bring the temp back down. With the ac on and idling you hit 205 you'll hear the second fan kick on and the temp come back down to around 199.
The max temp is much higher. Yes they can run around 220-230, and that is within normal range, with a cooling system working properly you should see 198's during normal operation.
Yesterday highway speed cruise to the beach (80 mi) with the top down and ac off, I ran 194-196 most of the way (it was 88 out) until I got to A1A and stop lights. While waiting at a light ac off, the temp climbed to 203, then I switched ac back on to regulate temps they got to 205 and dropped back down to 198 for the rest of the trip south about 20 miles. Coming back home late night around 70F out, top up ac on total highway cruise 196-198.
It's always operated that way since new. Except when it gets clogged up, then I notice the temps a little higher and that's my clue to give it a cleaning.
Appliance brush shown.
Top of intake area.
Flashlight there for scale to show how much stuff comes out and that's at a regular cleaning interval.
Yeah it's amazing how much material will collect in that small space between the condenser and radiator. If the vehicle is up in the air you can look between the from below. But to clean them you need to remove the cap.
