Driving without EBCM.
Old Sep 4, 2011 | 06:28 PM
Qwik01's Avatar
Qwik01
Default Driving without EBCM.
I took off my EBCM today so I can send it off. I drove the car around a while without it. Right away I noticed that the steering is a lot harder to turn at speeds under 20mph. Is this normal? At highway speeds it feels fine.
Old Sep 4, 2011 | 06:54 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I did not feel a difference in mine when I took it off to send it off for repair.
Old Sep 4, 2011 | 06:56 PM
RaW Z06's Avatar
RaW Z06
I was not aware the EBCM had anything to do with steering???
Old Sep 4, 2011 | 06:58 PM
Qwik01's Avatar
Qwik01
Yea, I know this sounds crazy but there is definetly a big difference in the effort it takes to turn the wheel. From a stop to a slow creep its almost like the power steering isnt even working.
Old Sep 4, 2011 | 07:10 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
No change when I did or sent mine off for repair.
Make sure you didn't hit the sensor on the rack when you removed the ABS Module
Thanks,Matt
Old Sep 4, 2011 | 08:45 PM
barrynk's Avatar
barrynk
I experienced the exact same phenomenon. Went away after I reinstalled the repaired EBCM, no harm done.
I can't explain it either.
Old Sep 5, 2011 | 12:35 AM
C5Luv'R's Avatar
C5Luv'R
My guess is the control for Magnasteer must be included in the EBCM. The Magnasteer system probably uses nearly the same vehicle data signals as the ABS system (wheel speeds, steering wheel angle, yaw, etc) in order to calculate the amount of steering assist.
Old Sep 5, 2011 | 12:39 AM
sweet97c5's Avatar
sweet97c5
Steering rack has magnet in it at top of rack where steering shaft bolts to it to assist with low speed steering, I believe is part of EBCM. I cant remember if all had them or not, depended on options.
Old Sep 5, 2011 | 12:40 AM
02koolC5's Avatar
02koolC5
It happened to me also,but went away after install of fixed EBCM
http://forums.corvetteforum.com/c5-t...to-arrive.html
Old Dec 5, 2017 | 07:33 AM
James McKee's Avatar
James McKee
5th Gear
It is safe to drive without ebcm for a short distance, under 3 miles?
Old Dec 5, 2017 | 10:24 AM
joezr2's Avatar
joezr2
ABSfixer says that it is: https://www.absfixer.com/FAQ.php
To Driving without EBCM.
