High temp fan?
Old Sep 4, 2011 | 10:58 PM
ZFLASH's Avatar
ZFLASH
St. Jude Donor '10-'11-'12-'13-'14, '16
Default High temp fan?
A little help please, I've noticed that my high temp fan won't come on. I've checked the fuses under the hood and they seem to be fine, are there any other fuses or switches I'm not aware of inside the car or underneath the hood? Thanks for your input in advance. L8R ZFLASH
Old Sep 4, 2011 | 11:03 PM
TriplBlk's Avatar
TriplBlk
Hmm"Lucky" would be a good one to contact, arnt they on a relay as well?
Old Sep 4, 2011 | 11:55 PM
ZFLASH's Avatar
ZFLASH
Thanks!
Old Sep 4, 2011 | 11:57 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
3 relays...
the driver side fan on YV's 02 is toast..hoping to get it fixed this week
Old Sep 5, 2011 | 12:00 AM
TriplBlk's Avatar
TriplBlk
Originally Posted by pewter99
3 relays...
yay I half knew/suggested something lol
Info absorbed
Old Sep 5, 2011 | 12:11 AM
ZFLASH's Avatar
ZFLASH
3 relays...
D*mn, I just sent you some $$$ for ST. JUDES, now I have this. What I did was installed Sac City's remote fan switch and this is when I found out it wasn't working. I thought it was just these H-town,TX, temps raising my temps. Well I hope to figure this out, thanks guys!! L8R ZFLASH
Old Sep 5, 2011 | 12:18 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Did you turn on the AC and see if both fans are working? In normal mode I believe the 2nd fan won't come on till 230.
Old Sep 5, 2011 | 12:27 AM
ZFLASH's Avatar
ZFLASH
I was waiting on you Mr. Bill! The remote fan kit I installed is intended to have them come when I use the remote, that way it comes on without hitting those temps. The car doesn't have to be on to test this, so I guess I need to run the a/c and get to temp and see if they come on. Anyway thanks for your help as always, while I have you, my horn doesn't work anymore. I had an in dash radar defuser/detector installed wondering if it could have been unplugged from inside the dash?
Old Sep 5, 2011 | 07:48 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Both fans will always run together. They are not commanded individually and yes, three relays control them. When they are supposed to run, always both.
To High temp fan?
