Skip Shift
Old Sep 5, 2011 | 03:58 PM
chasboy's Avatar
chasboy
Oldtimer
Default Skip Shift
What is the purpose of the skip shift? Is it on all 6 speeds?
Old Sep 5, 2011 | 06:51 PM
Highpower500's Avatar
Highpower500
It is a feature on some cars that forces you to shift from 1st to 4th at a certain RPM range once the engine hits a certain temperature. If you let the RPMs climb before you try to shift, the skip shift (CAGS for Computer Aided Gear Selection) won't kick in. I believe it was GM's way of getting around the gas guzzler tax.
When I first bought my Z06, it didn't bother me too much. However, after a while the car forcing me to shift from 1st to 4th became a major PITA. Installing a ship shift eliminator was once of the best moves I've done with the car so far.
Old Sep 5, 2011 | 07:23 PM
Hammer99's Avatar
Hammer99
Old Sep 5, 2011 | 07:36 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
and simple to do
http://shop.doubledmods.com/C5-and-C...?categoryId=-1
Old Sep 5, 2011 | 07:40 PM
dougbfresh's Avatar
dougbfresh
All in the OWNERS MANUAL.
Old Sep 5, 2011 | 07:42 PM
Highpower500
Originally Posted by c5 BearsFan
Absolutely! Even someone with no mechanical ability can tackle this modification.
Old Sep 5, 2011 | 07:53 PM
chasboy's Avatar
chasboy
Oldtimer
I'm not getting my car for another month, so I have not read the manual yet. The seller has one of those modules and is including it in the sale.
Old Sep 5, 2011 | 07:58 PM
dklowrider's Avatar
dklowrider
drive it for a little while before you install the skip shift eliminator. then you will appreciate your first mod.
Old Sep 5, 2011 | 09:39 PM
Nice that the car will have the CAGS eliminator already on the car. It's the first mod I did when I had both my 6-speed C5s.
Old May 10, 2021 | 12:24 PM
ohmygod's Avatar
ohmygod
Thanks for all the replies! I was in the midst of our first 2200 mile road trip and the grandson was asking if the car was fast, so we had to see. The trip went perfectly and the NCM & Tail of The Dragon were epic!
Old May 10, 2021 | 12:29 PM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
You might want to cut back on your drinking.
dan k.
Old May 10, 2021 | 01:08 PM
VETTEYOG's Avatar
VETTEYOG
2024 C5of the Year Finalist - Unmodified
When I first drove a vette, I said to myself, I can live with the skip shift feature.... then I drove in crawling traffic. Ordered the eliminator next day, never looked back!!
Old May 11, 2021 | 04:51 AM
strand rider's Avatar
strand rider
I wind my engine out to where I never notice the CAGS feature, save for the rare left turn when I have to keep an unusual speed and my gear selection is restricted to only fourth getting out of the hole. I suppose because I grew up driving low power English sports cars, I don't use the available torque well, preferring to run higher into the power band before shifting.
Old Dec 4, 2021 | 06:50 AM
ScottScott's Avatar
ScottScott
7th Gear
I heard all about this shift skip as I researched my 1st purchase, even ordered the bypass. Now after I've had it a month (2003 anniversary addition,) I don't think I'll even bother to take the time to put it on. I rarely ever hit the 1-4 skip. Only when in a low speed downtown or residential area if I'm REALLY conservative taking off from a light or stop sign. Mine will allow me to go into 3rd tho, will most not allow 3rd?
Old Dec 4, 2021 | 07:33 AM
JamesNC's Avatar
JamesNC
So are you saying that you pull away gently from a stop in first gear then shift directly into third gear?
FWIW, my friend has a Camaro that shares this feature and both of us discovered that shifting from first to neutral (allowing the shifter box spring to center the shifter) allows you to shift to second at will, essentially bypassing the CAGS.
That being said, like many on this forum, I eliminated this feature after driving mine the very first day
Old Dec 4, 2021 | 08:01 AM
ScottScott's Avatar
ScottScott
7th Gear
Yes, anytime I feel that block on 2nd I just go to 3rd instead of 4th. I have noticed that if you just pause in neutral for a second you can do what you want, which again in that kind of a low speed situation isn't a big deal either. I so rarely encounter it, even in slower downtown areas. If I see the light come on, I'll usually just stay in 1st for a little more....or go straight to 3rd.
Old Dec 4, 2021 | 08:21 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I have the skip shift tuned out but when not in a hurry I always shift 1-3-5. Doesn't lug the engine and saves me a few shifts.
To Skip Shift
Old Dec 5, 2021 | 12:37 PM
ScottScott's Avatar
ScottScott
7th Gear
Yes, I don't think that I have ever use all 6 gears at once. I may more often go 1-2-4-6, sometimes 1-2-3-6, or depending on speed I may settle at 5
Old Dec 6, 2021 | 05:41 PM
MattS in TN's Avatar
MattS in TN
"Save a few shifts" - why would you want to do that? You're missing half the fun of driving a stick!
Old Dec 6, 2021 | 06:53 PM
ScottScott's Avatar
ScottScott
7th Gear
To each his own.... The joy of driving manual for me doesn't come from merely pressing a pedal and moving a lever. It comes in picking the right gear for the situation, winding out lower gears for max acceleration, etc. If I get up to cruising speed after 3rd or 4th gear, it doesn't do much for me to pass through all of the rest.
