[Z06] Front end push?
Old Sep 7, 2011 | 10:13 AM
SweetZO6's Avatar
SweetZO6
Default Front end push?
When I turn my Z on loose gravel on black top, the rear tries to push it straight vice letting it turn. Is this normal?
When I turn into my gravel driveway off my gravel road it turns OK and does not try to go straight. I know the slip is not as noticeable on gravel but i don't end up inthe bushes.
I have Royal Purple gear oil in the rear.
Ed
Old Sep 7, 2011 | 10:52 AM
4GS7's Avatar
4GS7
If you're talking about about the front wheels skipping when close to full lock, like in a parking lot, that is a side effect of the Corvette's steering geometry. The way the front of the Corvette is set up, it cannot maintain proper Ackermann angle at full lock. It is well known and not indicative of anything being broken.
Old Sep 8, 2011 | 12:40 PM
SweetZO6's Avatar
SweetZO6
That is excatly what I'm talking about and you gave me the good answer.
THANKS for the help!
ED
Old Sep 8, 2011 | 03:31 PM
KrispyZ06's Avatar
KrispyZ06
What do you mean "proper ackerman"? Does it go to pro or anti ackerman?
Old Sep 9, 2011 | 09:58 PM
4GS7's Avatar
4GS7
I believe it's anti, as the rack is forward of the spindles. At full lock, the front wheels will still be parallel, leading to this skipping over marbles situation.
To Front end push?
