Odd headlight issue.
Old Sep 9, 2011 | 08:17 AM
Coyote's Avatar
Coyote
Default Odd headlight issue.
Here is an... odd.. one. My '99 Vette started to develop an issue where the passenger headlight would not come up every time I flipped the lights on. But sometimes it would. But, a few days after this started ... now when I lower the headlights (both previously UP), the passenger headlight lowers and continues to make a loud grinding sound for several seconds after to comes to the lowered position. It is VERY loud and noticeable (and sounds horrible). Also.. the odd part: Now, after this started happening, if I flip the light controls to the first stop position on the control-stalk, the headlights pop up but are not on. This is not the normal behavior. Normally it would just on the dash lights, fog lamps and parking lights... (which is nice because I don't like to always have the headlights UP when in semi-dim conditions). So.... Why in the world would the headlights pop-up on the parking-lights stop on the stalk... and why is that grinding sound occurring?
--Coyote
Old Sep 9, 2011 | 08:21 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Sounds like you need new gears.
DIY thread
http://forums.corvetteforum.com/c5-g...placement.html
Old Sep 9, 2011 | 08:29 AM
Coyote's Avatar
Coyote
Do you think the gear issue would cause the headlights to swing open (with lights-off) when the stalk controls are moved to the parking-lights position?
Old Sep 9, 2011 | 08:32 AM
JW Motorsports
Banned Scam/Spammer
Yes that's a common symptom of the headlight gears failing.
The machine gun sound (the grinding sound you hear) is def. telling me that. Been there and done that. It's an easy fix.
Old Sep 9, 2011 | 09:02 AM
C5 4 ME's Avatar
C5 4 ME
Old Sep 9, 2011 | 04:08 PM
FastAssVette's Avatar
FastAssVette
Your going to need new gears, mine did the same thing. The good news its a simple fix.
Old Sep 9, 2011 | 08:53 PM
Got to agree - I'd bet the plastic gears in the headlight motors are shot.
Old Sep 10, 2011 | 08:53 AM
Oldvetter's Avatar
Oldvetter
I agree with all the comments, a common problem and easy fix.
The "whys" behind this are as follows:
The headlights use an electronic black box, called the headlight module, (located behind the passenger headlights) to monitor the current that the headlight motors draw, when the motors hit their stops (up or down), the motor current spikes and the box shuts off the current.
What happens is the plastic gears wear down and they "slip". This slipping causes the "machine gun noise". When they slip, there is no current spike, so the motor keeps going until a "time out" limit is hit. But by doing this the "timing" is messed up and sometimes the lights will come up when only the parking lights are turned on.
Old Sep 10, 2011 | 09:09 PM
Coyote's Avatar
Coyote
Wow. Thanks for the detailed explanation. It makes more sense now and I don't to question the sanity of the car's computer. (at least not over this one).
Old Sep 10, 2011 | 09:50 PM
Bucky Barbour's Avatar
Bucky Barbour
I have the same issue. Does anyone know approximate cost to repair one light motor?
Old Sep 12, 2011 | 01:26 AM
SFL_driver's Avatar
SFL_driver
It seems like almost every single C5 has this problem.
Did mine about a year and a half ago.
Old Sep 12, 2011 | 02:13 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
$13.00 for the plastic gear at Advance Auto Parts. Dorman Part # 42400. I went with the plastic one cause the last one lasted 13 years. Some recommend the brass gear but it's heavier and cost three times as much.
Old Sep 12, 2011 | 11:53 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Easy fix and I would go with the brass gears.
Old Sep 12, 2011 | 12:35 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
I went with the brass gears as well. Just did this about a month ago. And it's amazing how loud that grinding noise is!!!!
Old Sep 12, 2011 | 12:50 PM
Chicago1's Avatar
Chicago1
Sure the brass one will never go out but the plastic one was way cheaper and will probably last another 60-70k like my last one. At 140k if i even still have the car I dought I will care about spending another 13 bucks and an hours worth of work. I bought the brass one but I should of had that mentality before I paid 50 bucks for it.
Old Sep 12, 2011 | 12:56 PM
C5 StockSwap
Cruise-In V Veteran
I look at it differently. What is best for the life of the car, not just me the current owner. I'd like to be able to tell the next owner that he/she doesn't have to worry about the shotty plastic gear...ever It is only one of many upgrades on this car.
To Odd headlight issue.
