installing rear bumper stainless letters
Old Sep 11, 2011 | 09:36 AM
Flh Den's Avatar
Flh Den
Veteran: Marine Corps
St. Jude Donor '13 thru '25
Default installing rear bumper stainless letters
Ordered a set of stainless rear bumper letters yesterday and was wondering if anyone has any advice on installing these straight. I know you are to clean the area with alcohol first, but one sight recommended spraying a little soapy water on first to be able to move them around in case they are a little crooked. Anyone have any experience installing these inserts.
Thanks Den
Old Sep 11, 2011 | 11:03 AM
ricknyc23's Avatar
ricknyc23
the stainless steel are pretty easy. its the vinyl that can be more difficult. Just make sure you clean the area with alcohol and use an adhesive promotor which usually comes with the letters.
Old Sep 11, 2011 | 11:24 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I used a Q-tip to help prep/clean the recessed areas and then used the 3M adhesive promotor pen. Press firmly and you should be fine. The only tricky part are the middle sections of the "E"s. If you don't get those on straight, they tend to reflect differently than the rest of the letters which are one piece. Tweezers usually help.
I do not recommend soap and water to help move the letters, because you don't want them to move. You have a few seconds to fiddle and adjust before the bonding process starts.
Good luck!
Old Sep 11, 2011 | 01:35 PM
guido7834's Avatar
guido7834
No soapy water! That is only for vinyl lettering applications. Clean with alcohol and good to go.
Old Sep 11, 2011 | 03:27 PM
New Owner Flynbya's Avatar
New Owner Flynbya
Acct suspended by request 10 Apr 2013
St. Jude Donor '10
the letters will look awesome on your car... can't give advice as when i bought my car they were already there. they make a big difference on the look of the back of the car.
enjoy... have fun and stay safe!!
Old Sep 11, 2011 | 08:27 PM
GETUONE's Avatar
GETUONE
From: Mobile,Alabama When someone tells me they've always wanted a Corvette,I say...GETUONE.
I'll state the obvious and say...DON'T DROP IT! After you've pulled off the paper backing that is. Make sure you are in a clean area or put some cardboard on the ground. Nice car.
Old Sep 11, 2011 | 09:50 PM
02koolC5's Avatar
02koolC5
I put the raised vinyl on mine...just start with a coner of the letter and slowly work the letter into the impression of the car, you'll be fine; just take your time and try to get a stool to sit on
Old Sep 11, 2011 | 10:10 PM
Just have a steady hand and be very patient when you put the letters on the fascia. When I installed my lettering kit, I gently placed the letter to the fascia - that way if it wasn't perfect I didn't have to pull hard to reposition it.
Old Dec 7, 2015 | 09:50 PM
Crussader's Avatar
Crussader
Sorry to bump an old thread, but I need clarification on this information. I got the stainless letters and I am not sure how to apply the adhesive promoter. I received a small tube of promoter with the letters. How much do I apply? What should I use as an applicator? How careful do I need to be that none of the promoter pushes out beyond the edges of the letters?
Old Dec 7, 2015 | 09:58 PM
Evilash's Avatar
Evilash
First thing to do is test fit the letters. My E's didn't fit flush and i had to file them down.
Clean the area with rubbing alcohol with a q tip to remove dirt and wax. Apply the promoter with a qtip if it didn't come in a small sponge applicator bottle. Don't worry about over shooting it'll clean off.
Follow directions for dry time and apply letters.
Been going strong 4 years now.
To installing rear bumper stainless letters
