Had my LG super pros installed and they made great power and amazing sound. Made 396 RWHP with LG super pros, bullets, intake and tune. I was just wondering why some LG super pros look different than these? Some look like their beefier which is the ones I wanted, could they not fit on the C5? I'm just making sure these are indeed the LG supers!
Maybe I was thinking the setup for the C6Z06/ZR1 for the 427, cause those things are ridiculous. Thanks for the help, much appriciated, as always Pics of the car coming soon
Is it possible I paid for super pros and got the pros? Lol are they the same price? It just threw me off cause they look different from the picture of the LG super pros
I'm pretty sure the Super Pros for C5 are still 1-3/4" but have the new merge collector and a velocity spike. We can't use the 1-7/8" because of the batwing oil pan, the 1-7/8" Super Pro's are for the C6's.
Originally Posted by Toque
The difference is in the Diameter of the pipes exiting the motor.
LG Pro's = 1 3/4"
LG Super Pro's = 1 7/8"
They both have 3" collectors, and are a 3" pipe from the collector back.
If you measure the diameter of the pipes "before" the 3" collector that should tell you if its the Pro's or the Super Pro's.
Nice numbers by the way ! I made 390rwhp with my LG Pro's, Vararam, Bullets, and tune.
Are you stating that the C5 can't use the "LG" 1 7/8" or any 1 7/8" setup due to the batwing oil pan? If that is the case, than you would be wrong, there are brands out there (KOOKS for one) that you can run their 1 7/8" LT on the C5 with no clearance issues, they are just a PITA to get in. I can't speak for the LG setup, that is why I asked.
Yes and no, I'm saying that i dont think LG offers the 1-7/8" for the C5 because the longer primaries won't fit around the oil pan in 1-7/8" , if you look at the picture above you can see the long primaries extend farther back. The 1-7/8" offered by ARH, Kooks and C6 1-7/8" LG Super Pro's are all are similar (shorter) in length. Go to website and take a look at the pictures and product details. I would suspect that cutting the length of the primaries for a bigger tube may not be worth the sacrifice in torque on the 5.7L that it may be for the 6.0, 6.2 or 7.0L.
-Micah
im almost certain LG makes 1 7/8" headers for C5/ZO6. I have the LG STREETS and they are for a fact 1 3/4". Im pretty sure the LG pros or now super pros are 1 7/8"
Nope, read closer 1-7/8 are for C6/Z06, could you get them to fit ? Probably but they aren't made for C5's, all the headers listed for C5's are 1-3/4" both the Streets and Super Pro's. The difference is not the header tubes, it's the collectors and the mid pipes. The 1-7/8" look more like Kooks or ARH with shorter tubes
Are you sure? My buddy said they come in 1 7/8". He ran both on his C5 I believe. They make them bigger for if u plan on doing a heads/cam application. Measured mine out yesterday and it looks like they are definitely bigger than 1 3/4"
The 1 7/8" super pros are for the c6/z06 because they have a bigger displacement engine (not to mention higher compression). The 5.7 doesnt need 1 7/8" primaries unless it is a "wild" built engine or running some sort of forced induction. Hence why you made almost 400 whp with 1 3/4" headers. They are perfect for the non-built ls6. In fact, I bet your bottom end power would suffer with 1 7/8" due to lack of back pressure.
Like I said he may have been able to make them fit but they are not offered for a C5 specific application. Truth is that these cars are so close that it probably would fit with minor tweeking. But I wouldn't risk spending $1600 to possibly have to hack up a new set for minimal HP gains and lose TQ.
Are all of you aware that L.G. uses 1 3/4-inch headers on their race Corvette?
The only reason they made the 1 7/8-inch headers is because some buyers wouldn't listen to their data that says the 1 3/4-inch headers make better low and mid-range torque, while giving away very little at the top-end of the rpm range.
The only reason they made the 1 7/8-inch headers is because some buyers wouldn't listen to their data that says the 1 3/4 make better low and mid-range torque, while giving away very little at the top-end of the rpm range.
A) good piece of info, I didn't know that!
B) Word
Bought mine fall of 2010 from LG and they told me the superpros are the new and improved pros better merge collector. they dont call them pros anymore now its superpros.
thats how i understood the sales guy at LG mine are 1-3/4''
Steve
LG Pro's = 1 3/4"
Toque
Nice....these cars are amazingly consistent.....I made 391rwhp with similar(ARH 1 3/4" with X-pipe)mods(less bullets).....added those later, hopefully didn't lose power but it made the car sound AMAZING
