weird 6 speed trans issue
Old Sep 12, 2011 | 07:43 PM
rootpooty's Avatar
rootpooty
Default weird 6 speed trans issue
I need some help solving this issue on what this could be. All of a sudden it is very difficult to get the car into first gear. If I put the shifter into neutral and move it to the left and attempt to put it into first it will go into third instead. There is no grinding or anything like that. The car will go into first but you have to put a little effort and pull the shifter to the left then forward to go into first but nothing like it should be.
About 2 months ago i had a C6 shifter and box installed and I must say it feels sloppy. After the install getting the car into reverse sometimes is a pain. The stock shifter just felt firmer but with a longer throw. Is there any adjustment needed when installing a different shifter? I contacted my installer about the issue and without him looking at it he said its quite possible that the first gear synchro is shot. Wouldn't it grind if the synchro is shot?
Suggestions?
Old Sep 12, 2011 | 09:02 PM
dklowrider's Avatar
dklowrider
your problem is most probably the shifter itself or alignment. was it a new or used shifter? does your installer know how to install one of these shifters? i'm a little skeptical after the bad syncro comment. did your car have this problem before the shifter install?
Old Sep 12, 2011 | 09:11 PM
rootpooty's Avatar
rootpooty
thats what it feels like is a bad alignment. it feels as if the alignment for first shifted or something. i had no shifting issues before the c6 shifter install. i purchased the shifter off another forum member
Old Sep 12, 2011 | 09:16 PM
qipman's Avatar
qipman
You might want to first try re-aligning your shifter following these instructions:
http://rpmtransmissions.com/files/c5...adjustment.pdf
Old Sep 12, 2011 | 09:19 PM
yaknow's Avatar
yaknow
sounds more like an alignment issue, the C6 shifter should be very similar in feel to the C5 except for the lenght of the throw
Old Sep 12, 2011 | 09:39 PM
cdkcorvette7's Avatar
cdkcorvette7
If your alignment pin is missing you can use a 5/8" drill bit... Just don't drop it...
Old Sep 12, 2011 | 09:57 PM
dklowrider's Avatar
dklowrider
but, i always thought it was proper to tighten the shift rod bolt before tightening the shifter mounting bolts. [?]
Old Sep 13, 2011 | 04:12 AM
airbrush1's Avatar
airbrush1
I can almost garuntee that the torx bolts that hold the shifter mechanism to the actuator rod have come loose... Same thing happened to my car after the shifter install. Follow the above links and do a re-alignment, and you will solve the problem!
Old Sep 14, 2011 | 01:11 AM
qipman's Avatar
qipman
Do you actually use a torque wrench to tighten the 3 torx bolts down to 22 lbs? I priced torque wrenches tonight and they are 70 dollars and up. I assume that many people just tighten by hand/feel.
Old Sep 14, 2011 | 01:35 AM
airbrush1's Avatar
airbrush1
I hand tightened them, and used blue loctite
Old Sep 14, 2011 | 03:15 PM
cdkcorvette7
You can probably get away without one for this job... But if you do a lot of your own work a torque wrench is one of those must-have tools... They have some good deals on amazon.
Old Sep 15, 2011 | 11:07 PM
qipman's Avatar
qipman
Thanks, picked one up tonight.
Old Oct 22, 2012 | 06:53 PM
TC_1961's Avatar
TC_1961
I hate to be "that" guy. Bringing up an old thread.
Searching on how to re-align shifter....and the above link doesnt work
Thanks all
Shoulda kept looking before dredging this up.
http://forums.corvetteforum.com/c5-t...-question.html
To weird 6 speed trans issue
