P/N for shift boot plastic piece?
Old Sep 13, 2011 | 12:14 PM
Chicago1's Avatar
Chicago1
Default P/N for shift boot plastic piece?
Anyone know if you can order the plastic part that the shift boot gets stapled into? If so what is that part number? Mine broke in a few pieces and I have a new 2 tone shift boot that I would like to install. Thanks
Old Sep 13, 2011 | 01:05 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I think it is #YOUARESCREWED...
you will need to buy the entire shifter assembly...thanks GM.
Old Sep 13, 2011 | 01:11 PM
hotwheels57's Avatar
hotwheels57
Incorrect. It's been discussed often in C5 Tech. You do have to buy a new oem boot to get the oem plastic ring. You might get lucky finding a used boot with an intact ring.
Or, there is a vendor on EBAY that sells a replacement stainless steel retaining ring, but it's not inexpensive...
http://forums.corvetteforum.com/c5-p...boot-ring.html
There was a member who had one of the stainless steel retaining rings for sale about a month ago.
Old Sep 13, 2011 | 03:45 PM
Chicago1's Avatar
Chicago1
^ That's much cheaper then buying a new one thanks for the link!!!
To P/N for shift boot plastic piece?
