Max power: 535.9 HP @5950 RPM
Max Torque: 544.6 ft-lbs. @4500 RPM
The tuner and I were both surprised to see the torque numbers higher than the HP. A good surprise I might add.
The car accelerates at an incredible rate has great street manners with little to no surging. We still have to fine tune the idle, the 102mm throttle body and a huge cam make it difficult. It looks like i can say "good bye" to fuel mileage. I expected it so its no surprise but it sure will be missed.
Overall I am highly pleased with the build and the outcome. The driving experience takes on another dimension with that kind of power on tap.
Originally Posted by Pete W
Is this an iron block, or ......? If it is the iron block, what is the weight difference from the LS1 motor. Thanks.
It is the iron block and from what I have seen others say who have weighed them it's 70lbs heavier.
Hello Ten's. Break that bad boy in then take it to the track. That should be a very fast car. I think there will be a lot of shocked C6 Z06's when you come up on them.
Max Torque: 544 ft-lbs. @4500 RPM
Those numbers are really awesome -
Imagine a set of Turbo's on there and what the TQ numbers would be and at maybe 8 PSI of SAFE Boost too!
Marc, good talking with you tonight man sounds like the car is a beast for sure and you should really do good when you get it to the track man. Give me a p.m. if you go I will come down and go and put down some C6 Z06 cars for sure.. Will come by at your set up at corvette expo in a week are so..... Robert
^ My garage is about 50ft from my neighbors bedroom wall so when I am taking home a date at midnight during the week im sure they have said a few choice words about me and the car. The H/C Ls6 was bad but this 408 is down right nasty sounding.
Who is your tuner, someone local that you would recommend?
I used Lane Culver in Huntsville, AL. Hes about 90 minutes from me and does great work. There is another tuner here in Nashville that i normally use however he was out of town when i needed it done.
