C5 Speedometer problem!
Old Sep 15, 2011 | 12:45 PM
Davidbohm's Avatar
Davidbohm
5th Gear
Default C5 Speedometer problem!
Hello out there!
I got some problem with Speedometer on my C5, i Changed the speed Sensor A today but still didnt work! My fuel meter aint workin aswell but ive heard its an common problem!
Any ideas?
Old Sep 15, 2011 | 02:30 PM
cdkcorvette7's Avatar
cdkcorvette7
Pull your DTC Codes and post them...
Courtesy of Bill Curlee:
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Sep 16, 2011 | 11:41 AM
Davidbohm's Avatar
Davidbohm
5th Gear
Default Problem with speedometer and fuel gages! Didnt work
Heey
The codes are:
P.0452 Fueltank pressne signel circuit input below minimun
P.0608 VSS output circuit
Ive been removing them from the data but they keep showing up, Soo i now wonder if you guys know how to fix this. As i said i've been changing the speedsensor
Old Sep 16, 2011 | 01:18 PM
Kevin Kuse's Avatar
Kevin Kuse
You need to fill out your Public Profile. Having more Info about the car will make it easier for people to help you!
Old Sep 17, 2011 | 06:53 AM
Davidbohm's Avatar
Davidbohm
5th Gear
Default Done with my profile
Heey,
Thank you! Im done with my profile now!
Old Sep 17, 2011 | 09:21 AM
Kevin Kuse's Avatar
Kevin Kuse
Welcome, is the odometer working (miles traveled)? But the speedometer is not working (how fast)? Is that is true you may have a bad Head unit. If both are not working then you may have a signal problem. Do you have an A4 or M6? If you have an A4 and it is automatically shifting correctly, more than likely the PCM is seeing the VSS. Then the problem would be between PCM to the Dash. Do you have a scanner to check the VSS signal at the PCM? Scan and check for a VSS signal if there is no signal the problem is between the VSS to PCM. If you get me your email address I will send you wiring diagrams.
Old Sep 17, 2011 | 11:33 AM
Davidbohm's Avatar
Davidbohm
5th Gear
I find out that i had a ground problem behind the battery, i just putted some electric contact spray the ground point, and now tis working perfect!
Thanks anyway guys!
Old Oct 6, 2011 | 10:01 PM
bigbonder's Avatar
bigbonder
hey guys I know this is the c5 section but i couldnt find anything on the c6 section about this. I am having the same code p0608 right now. I pulled off my knock sensor plug and changed my sensor and then plugged it back in and now the speedo isnt working and im getting code p0608,. Please help
Old Oct 7, 2011 | 01:46 PM
Davidbohm's Avatar
Davidbohm
5th Gear
Check all ground points! make sure they got contact, you could also spray some contact spray on them! some of them are really hard to find!
Old Jan 2, 2012 | 03:14 PM
jrstoyvette's Avatar
jrstoyvette
1st Gear
Does anyone know a company that does speedo repair on c5. my DIC buttons do not work
Old Jan 2, 2012 | 06:21 PM
cdkcorvette7
You should start your own thread in tech. The wiring harness on the back of the cluster may have just come loose. It's a press fit, there's no retaining clip. You should pull your cluster and make sure that harness is secure.*
Old Aug 9, 2013 | 04:41 PM
Tim88's Avatar
Tim88
8th Gear
My car is having the same problems. I own a 97. I went through the steps trying to figure out what is going on but the reset and option switch must not work because nothing changes on my dash? Worked last night when I put my new cluster in but not tonight.. I am not sure what the problem is but when I start the car the tack goes to like 200 or what ever the cars high speed is then it goes to zero.. never leaves that spot after that..
Old Jun 18, 2019 | 08:04 PM
waynepeg's Avatar
waynepeg
Cruising
Hi, Can you share where this ground points are located?
Old Jun 18, 2019 | 08:06 PM
waynepeg's Avatar
waynepeg
Cruising
Old Jun 19, 2019 | 09:09 AM
Kevin Kuse's Avatar
Kevin Kuse
To C5 Speedometer problem!
