Clutch Fluid?
Old Sep 18, 2011 | 07:36 PM
McLendon95's Avatar
McLendon95
Default Clutch Fluid?
Just a really quick question. How cool should the clutch fluid be before change? I'm about to change the fluid, and I was just driving the car about 45 minutes ago. Is it still too hot to change?
Old Sep 18, 2011 | 08:27 PM
bartsky's Avatar
bartsky
I change my with Ranger Method just as soon as I pull into my garage.
Old Sep 18, 2011 | 08:30 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Yep! I don't think the temp matters, especially with Ranger's method. Search this forum for Ranger's clutch fluid replacement method. It's easy. Zuti
Old Sep 18, 2011 | 08:47 PM
Omaha02Z06's Avatar
Omaha02Z06
Old Sep 18, 2011 | 11:24 PM
m6 c5's Avatar
m6 c5
Ive changed mine >10 times in the past three weeks or so, fluid has been cold, hot and everything in between no problems here. Its finally coming out clear so I should be done changing it like that.
Old Sep 19, 2011 | 07:37 AM
johnson-rod's Avatar
johnson-rod
Temp doesn't matter with Clutch fluid.
Blinker fluid - now that's a different story.
To Clutch Fluid?
