Dash Light Dimmer Knob
Old Sep 22, 2011 | 01:04 AM
ObieAnderson's Avatar
ObieAnderson
6th Gear
Default Dash Light Dimmer ****
Any tips out there as to where one might look for a **** for the dash light dimmer on a C5?
thanks,
Obie
Old Sep 22, 2011 | 07:30 AM
nodima's Avatar
nodima
I think it is on the dash to the left side of the steering wheel, just below the controls for the HUD
Old Sep 22, 2011 | 07:37 AM
widewheel's Avatar
widewheel
If you mean where is it on the dash Nodima is correct. It is like the radio tuning ****, push it in and it pops out to adjust and then push it back in. If you mean where to get a replacement I would suggest the dealer.
Old Sep 22, 2011 | 11:46 AM
ObieAnderson
6th Gear
thanks,
Obie
Appreciate the feedback and yes, the **** for my switch is missing so I'm trying to chase down a replacement. Don't like going to the dealer but that will be the next stop. Thanks.
Old Sep 22, 2011 | 02:52 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
there are several corvette only salvage yards (a google search will turn them up) if you want to spend a bit of time making a couple of calls before you visit the dealer. you never know what they may or may not have. several specialize in newer wrecks.
Old Sep 22, 2011 | 03:19 PM
ObieAnderson
6th Gear
Thanks, I will do that. Just found that this part has been discontinued and is not available from the dealer.
Appreciate the suggestion.
Old Sep 22, 2011 | 03:26 PM
nodima's Avatar
nodima
ooof - a swing and a miss! lol
Good luck locating the part you need!
Old Sep 22, 2011 | 03:39 PM
ObieAnderson
6th Gear
It's all good. I'm having fun messing with the car and this forum is the best.
Old Sep 22, 2011 | 05:27 PM
srs244's Avatar
srs244
try "just corvettes" out in missouri or "sutton automotive" in nebraska. there are others, but i have had some pretty good luck with both of these (with parts for my C3, but they are all years salvage yards, ) your profile doesn't have your location. perhaps one of these is in your backyard. good luck
Old Sep 22, 2011 | 05:46 PM
ObieAnderson
6th Gear
I'm in the SF Bay Area, but will check with these yards. An item this small would be easy to mail. Thanks for the suggestions.
Old Sep 23, 2011 | 12:55 AM
Try the used parts vendor here on the forum - they might have the piece.
Old Sep 23, 2011 | 06:14 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Sounds like you are in the same boat I am.
I am missing the HUD brightness control ****, can't find it anywhere because used parts places want to sell the whole HUD control unit and so does GM.
You can't just buy the **** at the dealer, you have to buy the whole control unit for $125.00
Old May 24, 2013 | 01:16 PM
Fox56's Avatar
Fox56
5th Gear
Default C5 Dimmer **** Replacement
As a follow-up to an old thread ... go to Radio Shack and purchase item # 274-403 - 1/2" Control ***** (2) - for $2.99, then grind a relief on the raised section to allow it to be retracted into the dash. Use a Sharpie to color the cap black instead of blue.
Old May 25, 2013 | 12:58 PM
dadaroo's Avatar
dadaroo
There are also used units on eBay for sale. You could buy one and just remove the ****. The Radio Shack approach would be much cheaper if you didn't want an exact replacement.
To Dash Light Dimmer Knob
